 Post subject: New to data recovery - clicking question
PostPosted: July 2nd, 2014, 7:03
Sorry if this is rather basic, but would appreciate some advice here. I have a 500GB 2.5" SATA Fujitsu drive. When I connect it to Deepspar, it takes about 2 minutes to see something there, but it does not detect the drive type and just shows up with 'Drive is not responding PHY=3'
I can hear the heads sweeping and clicking away - scanning followed by 2 faint clicks. In my limited experience with hardware issues, I figured it was a problem with the heads. Before I told the customer this would likely be a costly fix, is there anything simpler it could be?
 Post subject: Re: New to data recovery - clicking question
PostPosted: July 2nd, 2014, 8:54
I do not know DeepSpar tools, but maybe heads problems or FW problems.
But you need a testing tools for be sure about it.
god luck!
PostPosted: July 2nd, 2014, 15:51
Bad heads for sure.
PostPosted: July 2nd, 2014, 17:05
Clicking drives are usually related to heads, though other things such as an incompatible PCB can also cause it.
PostPosted: July 2nd, 2014, 17:10
You should diagnosis the clicking issue before you put it on a disk imager. You could make the problem worse or even unrecoverable by skipping diagnostic steps.
PostPosted: July 3rd, 2014, 3:38
Thanks, thought it was likely a heads issue. I don't think the customer will want this data enough to spend the cash.
Users browsing this forum: No registered users and 70 guests
