 Post subject: ST500DM002 BUSY
PostPosted: May 22nd, 2014, 8:42
HELLO!
Not access terminal...
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
Busy 100%, rpm ok, not sound (clicks, clicks)...
Нет ничего невозможного
 Post subject: Re: ST500DM002 BUSY
PostPosted: May 22nd, 2014, 16:37
Short read channel on PCB for starters
Data Recovery Cape Town
PostPosted: May 23rd, 2014, 12:29
How to short??????
PostPosted: May 23rd, 2014, 14:26
Yes short channel pcb...
Sorry, not access terminal...
Is bad heads?
PostPosted: June 10th, 2014, 9:17
Is bad heads?
Swap heads... is busy ....
log terminal
Boot 0x10M
Spin Up
RECOV Servo Op=0100 Resp=0005[0x00000000][0x0000BA10]
Trans.
Rst 0x10M
Spin Up
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
RECOV Servo Op=0055 Resp=0005
RECOV Servo Op=0165 Resp=0005
RECOV Servo Op=0065 Resp=0005
(P) SATA Reset
PostPosted: June 10th, 2014, 16:34
Be patient
PostPosted: June 10th, 2014, 16:44
labtech wrote:
Be patient
SOLVED!
HEADS ORIGIANAIS...
PostPosted: June 11th, 2014, 8:15
longlife wrote:
How to short??????
yes!!
PostPosted: June 11th, 2014, 8:36
sempre wrote:
labtech wrote:
Be patient
SOLVED!
HEADS ORIGIANAIS...
I'm very sorry but i'm having a hard time trying to understand your posts.
Can you please elaborate on how did you manage to solve the problem with the drive ?
PostPosted: June 11th, 2014, 9:01
Any kindhearted expert, please explain in what is written in this thread.
PostPosted: June 11th, 2014, 9:33
According to the terminal log, everything is OK with the drive.
With the info available for now there's nothing else to explain.
PostPosted: July 8th, 2014, 7:17
could tell me what the pin as do the short read-channel in the pcb?
thanks in advance
PostPosted: July 8th, 2014, 7:44
thanks in advance
Check this thread:
http://malthus.zapto.org/viewtopic.php?f=24&t=123&p=1632&hilit=read+channel#p1632
PostPosted: August 5th, 2014, 4:40
Yesterday I was trying to unlock the terminal hard disk
Short read channel on PCB but did not have access
In the terminal reports me the following:
FAIL Op = 0100 Resp Servo = 0007
2BA0 ResponseFrame 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
LED: 000000EE FAddr: 0010289C
What can be happening? Please I need help.
Thanks in advance
PostPosted: November 22nd, 2014, 13:10
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
0000 0000 0000 0000
Thanks in advance
Same error, same symptom
Is there a any help?
Users browsing this forum: we3fan and 215 guests
