 Post subject: Seagate ST31500341AS 7200.11 Making Constant Beep Noise
PostPosted: August 28th, 2014, 14:57
My Seagate ST31500341AS 7200.11 Drive makes a constant Beep... Beep... Beep... Noise can anyone give me a idea of what the problem could be I know this particular drive usually has firmware problems along with others, Thought that it could be the heads stuck to the platter but it sounds slightly different from that.
 Post subject: Re: Seagate ST31500341AS 7200.11 Making Constant Beep Noise
PostPosted: August 28th, 2014, 15:20
Almost certainly seized motor.
PostPosted: August 29th, 2014, 0:14
Any quick fix that you know of? Money is not a problem, I want this for my knowledge. Maybe a project to do on my own.
PostPosted: August 29th, 2014, 2:55
No quick fix.
Not DIY, a difficult job even for most "pros"
PostPosted: August 29th, 2014, 7:15
very probably spin reseizure.
Not easy work, you need tools and knowledge.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], vmsameer and 153 guests
