 Post subject: compatibility of heads in western digital
PostPosted: September 9th, 2014, 8:55
Hello everyone.....
I made a head change in a western digital . the problem is that in the client's disk we don't get into the data, altough in donor disk with thtat head we can see the files. the donor correspond to matching guide needed for western digital. I checked on pc 3000 and the heads are ok.
Exists some problem on compatibility of heads in western digital? where can I study about that?
 Post subject: Re: compatibility of heads in western digital
PostPosted: September 9th, 2014, 9:17
Bom dia,
What were the symptoms BEFORE you changed the heads? Could you "get into the data" with the old heads, but not the new? I'm trying to determine if you have a heads issue, or something else.
http://www.datasaversllc.com
PostPosted: September 9th, 2014, 9:21
if you return donnor heads to donnor drives, continue reading on donnor drive?
PostPosted: September 9th, 2014, 9:34
Is this an external drive?
Y'see, a lot of questions, which means you need to be more specific in order to get help by others.
PostPosted: September 9th, 2014, 10:25
jono-ats wrote:
Bom dia,
Boa tarde...
o que tenho é um disco western dum cliente o diagnóstico determinou cabeças partidas, fiz então a compra de um donor, e troquei as cabeças contudo não consigo chegar aos dados do mesmo, porém trocando as caças ( em bom estado) para o donor estas funcionam conseguindo ver a NTFS do donor enquanto que estas cabeças em bom estado não funcionam no cliente.
A minha questão é se existe algum tipo de incompatibilidade nos western que não existe noutros casos uma vez que já efectuei mudanças noutros discos e correu lindamente.
PostPosted: September 9th, 2014, 10:28
WD heads are fairly compatible.
What model are you working with? You may have a firmware issue unrelated to heads.
PostPosted: September 9th, 2014, 10:29
Good afternoon ...
what I have is a western disc of a client's diagnosis determined broken heads, so I made the purchase of a donor, and changed the heads but can not get to the data of the same, but replacing the heads (in good condition) to the donor they work getting to see the NTFS donor while these heads in good condition do not work on the client.
My question is if there is some kind of incompatibility in western that does not exist in other cases since I performed since changes in other disks and ran beautifully.
PostPosted: September 9th, 2014, 11:23
I understand your question. You do not understand mine. :)
PostPosted: September 9th, 2014, 11:30
There are "rules" for WD head swaps, but they depend upon model number, to some extent.
No, I am not going to tell you everything I know about WD heads compatibility. There are a lot of different "rules", although most have a lot in common. But if you can provide the model number of the drive in question, perhaps I can help you with this recovery.
Damaged heads can harm the SA modules necessary for the drive to start up. Some WD models seem more prone to this type of damage than others.
So, the next step is up to you . . .
PostPosted: September 9th, 2014, 11:42
the Model I have is : WD10EALX - 009BA0
PostPosted: September 9th, 2014, 15:19
That's a Tahoe2D. Should have 4 heads, so heads map isn't an issue. Microjogs should be within 200 between patient and donor. Check sliders of patient and donor to confirm that they match.
I think you have an SA / firmware issue.
Jon
PostPosted: September 9th, 2014, 15:29
The WD10EALS-00Z8A0 drive for donor could be good too.
If after a head swap the drive is not identifiable, then there could be a damaged SA, or corrupted firmware modules....
Try read firmware modules with PCB hot swap
Users browsing this forum: No registered users and 53 guests
