 Post subject: Fujitsu MHZ2250BS G2 / Write Cache utility
PostPosted: September 17th, 2014, 11:06
I got 2 of these drives removed from HP SATA caddies, and I'd like to reuse them as USB drives.
These seem to have Write Cache disabled from factory, and I've noticed it can be temporarely reenabled under linux with HDPARM, or the HDAT2 utility.
Is there a known utility that would allow me to set it as enabled from spinup?
Can't seem to find such a thing for Fujitsu drives... only other manufacturers.
 Post subject: Re: Fujitsu MHZ2250BS G2 / Write Cache utility
PostPosted: September 17th, 2014, 11:34
CAn you say us model, and identification data about drives?
With this info people here can help you in the correct way.
thanks
PostPosted: September 17th, 2014, 12:09
From the label, this SATA 250GB/5.4k drive is:
Fujitsu Model MHZ2250BS G2
From HDPARM Id, it is rebranded as:
HP Model GJ0250EAGSQ
FW Revision: HPG2
output from hdparm -I /dev/sdb
/dev/sdb:
ATA device, with non-removable media
Model Number: GJ0250EAGSQ
Serial Number: K648TB128RKG
Firmware Revision: HPG2
Transport: Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5; Revision: ATA8-AST T13 Project D1697 Revision 0b
Standards:
Used: ATA/ATAPI-7 T13 1532D revision 4a
Supported: 7 6 5 4 & some of 8
Configuration:
Logical max current
cylinders 16383 16383
heads 16 16
sectors/track 63 63
CHS current addressable sectors: 16514064
LBA user addressable sectors: 268435455
LBA48 user addressable sectors: 488397168
Logical Sector size: 512 bytes
Physical Sector size: 512 bytes
device size with M = 1024*1024: 238475 MBytes
device size with M = 1000*1000: 250059 MBytes (250 GB)
cache/buffer size = 8192 KBytes (type=DualPortCache)
Nominal Media Rotation Rate: 5400
Capabilities:
LBA, IORDY(can be disabled)
Queue depth: 32
Standby timer values: spec'd by Standard, no device specific minimum
R/W multiple sector transfer: Max = 16 Current = 16
Advanced power management level: disabled
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
Cycle time: no flow control=120ns IORDY flow control=120ns
Commands/features:
Enabled Supported:
* SMART feature set
* Power Management feature set
Write cache
* Look-ahead
* WRITE_BUFFER command
* READ_BUFFER command
* NOP cmd
* DOWNLOAD_MICROCODE
Advanced Power Management feature set
* 48-bit Address feature set
* Device Configuration Overlay feature set
* Mandatory FLUSH_CACHE
* FLUSH_CACHE_EXT
* SMART error logging
* SMART self-test
* General Purpose Logging feature set
* WRITE_{DMA|MULTIPLE}_FUA_EXT
* 64-bit World wide name
* IDLE_IMMEDIATE with UNLOAD
* WRITE_UNCORRECTABLE_EXT command
* {READ,WRITE}_DMA_EXT_GPL commands
* Segmented DOWNLOAD_MICROCODE
* Gen1 signaling speed (1.5Gb/s)
* Gen2 signaling speed (3.0Gb/s)
* Native Command Queueing (NCQ)
* Phy event counters
DMA Setup Auto-Activate optimization
* Software settings preservation
* SMART Command Transport (SCT) feature set
* SCT Read/Write Long (AC1), obsolete
* SCT Write Same (AC2)
* SCT Error Recovery Control (AC3)
* SCT Features Control (AC4)
* SCT Data Tables (AC5)
Logical Unit WWN Device Identifier: 500000e044933b0e
NAA : 5
IEEE OUI : 00000e
Unique ID : 044933b0e
Checksum: correct
PostPosted: September 18th, 2014, 22:18
Mario wrote:
I got 2 of these drives removed from HP SATA caddies ...
These seem to have Write Cache disabled from factory...
If I recall correctly, Fujitsu hard drives use module 07 (cp07) to store different attributes and options.
Compare those modules in FWs from a generic drive and an OEM one of the same model.
PostPosted: September 19th, 2014, 19:40
FWIW, here are several tools for old Fujitsu models:
http://aplex86.narod.ru/firmprog.html
I don't know if they are safe to use with MHZ models. In any case I would limit any experimentation to reading the ROM and modules, not writing them.
The following article might be of interest to you.
MHDD script for retrieving Fujitsu HDD modules:
http://www.alexsoft.org/viewtopic.php?f=91&t=987&p=4313
PostPosted: September 22nd, 2014, 15:55
These 2 drives are mostly for fun/learning as they're barely usable (slow) without cache enabled.
I will read all that info before experimenting, but the greatest challenge will be finding a known good module to compare with.
Users browsing this forum: No registered users and 63 guests
