Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Is any hope for my WD elements 2TB usb3.0?
PostPosted: October 17th, 2014, 9:05
I have swap the rom to the Dona pcb and boot it in safemode. I also download the firmware. Should be the right one.
I can read rom out using wdmarvel, but it can not load module 11.
And I found out wdmarvel doesn't have shriek family!
Does it support Shrek family?
Need help.
PostPosted: October 18th, 2014, 18:35
Can you read the resources with SeDiv?
http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
http://sediv2008.narod.ru/Settings.rar
Can you upload all the modules that you can read with WDMarvel?
PostPosted: October 22nd, 2014, 1:15
Finally got the wd_marvel work. My PC's mother board is not compatible.
The HDD is in a very slow mode. It took me more than one hour to check half the modules. By now it's reading ID2514.
Looks like only ID04 is dead( can not read). ID24 CRC not valid.
In this family is ID04 the copy of ID03?
Slow issue is because of smart modules or weak head?
thanks again
PostPosted: October 22nd, 2014, 8:12
Looks like slow issue is because of the broken 04.
but I don't understand why broken 04 makes reading SA modules so slow.
PostPosted: October 22nd, 2014, 15:45
You really are in way over your head. Unless you've got a year to waste and a few thousand dollars to burn, you'd better just get it to a pro. Not an easy model even for the professionals to work on.
PostPosted: October 22nd, 2014, 19:56
Can you upload the modules?
PostPosted: October 22nd, 2014, 20:23
Attached is the first half. I stopped the reading process last night. I am reading the rest of them now.
It's a bit strange. Sediv can not run at all( error pops up in my win7 32bit ).
And the module file uploaded by WD_Marvel is not rpm file. They are MOD files.
thanks
WDC WD20NMVW-11AV3S4-01-0GG-WD-WX91A43R1983.rar [9.56 MiB]
Downloaded 1147 times
PostPosted: October 23rd, 2014, 4:19
This is a Shrek drive.
Good luck with it...
PostPosted: October 23rd, 2014, 8:16
Yep it is a Shrek. Is there any story about this monster? And module 04, looks like it's a big nut table.
Well after several weeks, at least I know I can do something, although I can not fix it at the moment.
PostPosted: October 27th, 2014, 8:25
I found something weird.
WDR shows control buffer size is 0KB.
I thought the 771931 is not compatible so I managed to take the four capacitors off the 771961 board and hard wired the sata to a sata connector. It's the same.
Does the wrong control buffer size mean something?
PostPosted: October 27th, 2014, 23:29
C:\>wd_smart 21.mod
ROYL header found
ID  Flg   Cur  Wor  Thr  Raw             Description
  1   2F   200  200   51  00000000000080  Raw Read Error Rate
  3   27   245  221   21  00000000000ABE  Spin Up Time
  4   32    99   99    0  000000000005E2  Start/Stop Count
  5   33   133  133  140  00000000000AF5  Re-allocated Sector Count
  7   2E     1    1    0  000000000073B6  Seek Error Rate
  9   32    97   97    0  00000000000AF2  Power-On Hours Count
10   32   100  100    0  00000000000000  Spin Retry Count
11   32   100  100    0  00000000000000  Drive Calibration Retry Count
12   32   100  100    0  00000000000295  Drive Power Cycle Count
183  *B2   100  100    0  00000000000000  SATA Downshift Error Count
184  *B2   100  100    0  00000000000000  End to End Error Det/Corr Count
187  *B2     1    1    0  000000000000A7  Reported Uncorrectable Errors
188  *B2     3    3    0  000008005D0062  Command Time Out
190  *A2    72   45    0  0000000000001C  Airflow Temperature
191  *B2    97   97    0  00000000000003  Shock Sense
192   32   200  200    0  0000000000022E  Emergency Retract Cycle Count
193   32   193  193    0  00000000005470  Load/Unload Cycle Count
194   22   124   97    0  0000000000001C  HDA Temperature
195  *B6   200  200    0  00000000000000  ECC on the Fly Count
196   32    61    1    0  0000000000008B  Re-allocated Sector Event
197   32   200  200    0  00000000000000  Current Pending Sector Count
198   30   100  253    0  00000000000000  Offline Uncorrectable Sector Count
199   32   200  200    0  00000000000000  UltraDMA CRC Error Rate
200   08   100  253    0  00000000000000  Multi Zone Error Rate
240  *B2   100  100    0  000000000001D1  Head Flying Hours
241  *B2   200  200    0  00000132B4F226  Total LBAs written
242  *B2   200  200    0  0000010C684E12  Total LBAs read
254  *B2   200  200    0  00000000000000  Free Fall Sensor
     * = hidden attribute
PostPosted: October 27th, 2014, 23:44
MOD 34 (G-list) has a lot of entries. I could be wrong, but ISTM that head #2 has problems.
I would try modifying MOD 02 and MOD 32 as in the following threads:
viewtopic.php?f=1&t=29187&start=20
http://www.alexsoft.org/viewtopic.php?t ... 4345#p4345
Hopefully you will be able to clone your drive with ddrescue (if your drive shows up in BIOS).
PostPosted: October 30th, 2014, 9:08
After lots of hours, finally it's fixed.
Thanks a lot fzabkar, although I didn't use your script.
I will explain tomorrow.
PostPosted: October 30th, 2014, 23:29
Last night when I had a look at Fzabkar's slowfix solution. I am not 100% sure it will work on my HDD, because in the sample MOD 02, address of flag "ODD" is not the same as mine, and I don't understand how the script clear that single byte.
Meanwhile I found a topic in a Chinese forum. They clear all the bytes to zero from flag "ODD" to "01 00 28" in MOD02( please see pic).
From the two solution, I am quite sure at least one will work. So I tried the Chinese solution using WDR5.3 first. And it works!
Now I am backing up bloody 1.6TB data to another wd element. It will take about 24 hours. Hope the old wd element will not brake down again.
And I am quite interested in what's the reason of slow wd, and why clearing MOD02 will fix it. Can any Guru explain?
Thanks a lot FZABKAR.
PostPosted: October 31st, 2014, 3:30
Congratulations.
My script is independent of the actual location of the relevant section within MOD 02. Also, instead of deleting this section, it merely disables it by writing a zero to byte position #02 within the section.
Perhaps the following article will be of help to you.
Analysis of Western Digital ROYL firmware MOD 02:
http://www.alexsoft.org/viewtopic.php?f=59&t=821&p=3191
PS. You can keep the $20. ;-)
PostPosted: October 31st, 2014, 8:14
good job biggerpizza, !!
PostPosted: July 28th, 2015, 12:35
I have similar problem, I have
WD My Passport Ultra 2TB,
HDD model inside WD20NMW-11AV3S2 and
PCB 2060-771961-001 REV A
One day it stopped working, no clicking noises, it spins starts moving head and after some time it stops spinning and starts again immediately again to spin... I suspected that it was head problem... So I ordered same disk, same specs and disassembled. Replaced heads and I got same problem on broken hard disk, and on new disk with old head I had no problems. It worked OK... After that I asked my friend to replace two BIOS IC, since I thought it is PCB problem... But after replacing BIOS IC's old disk was in slow mode as biggerpizza said. I could see size of disk and type of disk, but could not access disk files. So we decided to return BIOC IC's as they were originally. But then I have same problem and with the new disk, it is in slow read mode, and old one has same problems, stops spinning after some time. Interesting is that if I swap motherboards both of disks are spinning, I can hear head that is trying to read but never initializes... I don't see disk, I can see only My Passport 0820.
What to do now? Can you help me? Pleaseeeee :(
I will buy some beer to one who help me :beer:
PostPosted: November 15th, 2015, 5:27
We just had one of these drives. Same symptoms with slow read etc. Cloning would have taken a month and extraction of small jpeg files took about 5 to 10 minutes each.
As there was no on bridge encryption or WD smartware protection we just converted the existing pcb to sata. Tried cloning and file extraction and again it was very slow.
So then we backed up MOD 2. Just had to write back the edited module as in the post above and 'voila'. Drive reading at near normal speed. Data safely copied to a replacement.
I would like to thank biggerpiza for taking the time to post his solution!
PostPosted: November 16th, 2015, 13:14
Just got it and just tried to resolve slow responding problem in first time? It's look like you are from 2013.
PostPosted: February 26th, 2016, 16:07
Hi dick,How did you wrote MOD02 into the WD20NMVW Flash ROM? I used WDMarvel tool to write the edited version of MOD02 back to the flash ROM but after reading the MOD02 again to see if the changes were OK surprisingly NO changes whatsoever everything back to the original, So confusing!
Users browsing this forum: No registered users and 48 guests
