Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
 Post subject: Re: IO errors after head swap
PostPosted: February 11th, 2015, 14:08
kaxi wrote:
Is model number is the only thing you checked for HSA compatibility? If this is the case, you sould research a bit more for HSA compatibility criteria. It's all there.
Headstack matching for Western Digital:
http://www.hddoracle.com/viewtopic.php?f=86&t=1036
PostPosted: February 11th, 2015, 15:47
That's right - I'm NOT reading via SATA
http://www.computerworksuk.com
PostPosted: February 12th, 2015, 5:44
If you don't have the DDI USB add-on, converting to SATA would give you the only chance of recovery if media damage is involved. After imaging whatever is posible, then you can deal with the encription issue as a next step.
PostPosted: February 12th, 2015, 5:58
Yes I was afraid that was going to be the case. I've email Ace Labs for a quote
PostPosted: February 12th, 2015, 6:56
It's approx. €5,000
PostPosted: February 12th, 2015, 9:41
Seems pretty reasonable when you considered what their equipment is capable of and the support they offer.
PostPosted: February 12th, 2015, 11:05
Yes, it is :-)
PostPosted: February 12th, 2015, 13:23
It is certainly cheaper than having an own in-house engineering team making your own equipment.
PostPosted: February 12th, 2015, 14:56
You could apply that same argument to justify the price of a one million dollar car or television set.
I wonder what the price of tools would be if every potential developer had access to the same stolen/leaked information. There are plenty of intelligent people in the open source community who would very quickly change the shape of the data recovery business with free or affordable tools.
PostPosted: February 12th, 2015, 15:00
If you are reading the drive through the USB - stop. Results in most cases are bad. There is a procedure you can find on the forum that allows for SATA access ( removing 4 capacitors ) or in some cases you can use compatible SATA board ( there is a list on the forum as well ) But that in turn bypasses the encryption controller (depending on the drive Initio, jmicron, PLX ). I use data extractor for this next step , however you might be able to bypass that using the 3.5 sata to usb bridges from My Books ? Have any techs attempted that? Good luck.
PS my rule of thumb is if drive IDs with donor heads - i dont question compatibility =)
PostPosted: February 12th, 2015, 18:19
The most probably problem is media damage on 1 platter face. very probably too 1 badlly head.
the best is to take a look to all platter heads (but tools needed to extract heads, platters,..)
PostPosted: February 13th, 2015, 11:48
i had situations when a 2.5 usb3 wd would not even ID normally under USB conditions , but working with the same drive through SATA yielded close to 100% clean images.
PostPosted: February 13th, 2015, 13:57
pcimage. What do you mean OP? I've seen this scattered around the forum. What does it stand for?
PostPosted: February 13th, 2015, 14:41
Ah OK. Thank you
Users browsing this forum: No registered users and 35 guests
