 Post subject: WD firebird family 'encrypted firmware'
PostPosted: February 20th, 2015, 10:57
Hello
Can anybody remotely help or advice how to get to the SA on WD Firebird family?
SA is not accessible or encrypted.
we need to disable Auto-relocation
 Post subject: Re: WD firebird family 'encrypted firmware'
PostPosted: February 21st, 2015, 7:37
As far as I remember Igor (my colleague) found a solution for FW lock problem for most of WD/HGST drives.
Drop PM or send request to igor@d3consultyou.com.
VISUAL NAND RECONSTRUCTOR. Since 2014.
PostPosted: February 23rd, 2015, 6:34
I have a similar situation.
Have a FW locked HDD and want to REGENERATE Translator.
Any help is appreciated.
PostPosted: February 23rd, 2015, 13:11
These drives have factory locked SA access.
Therefore you can't perform any SA related actions like clearing Relo or Regen translator etc.
There is, however, a way to gain SA access and decrypt on-the-fly.
PostPosted: February 25th, 2015, 0:09
Tried SA Region editing and then to get the SA access but no luck with that as well
Any pointers / suggestions ??
PostPosted: February 25th, 2015, 5:16
With SA Region Editing i could get access to SA and was able to save all the Modules as well.
All modules are OKAY except for Relo.
Moment i load the Loader it locks the SA and w/o loader i am not able to edit any Mods to CLEAR Relo.
PostPosted: February 26th, 2015, 14:37
ROb
You could not put the resources from this disk on file sharing?Thank you.
PostPosted: February 27th, 2015, 7:06
I have uploaded them here
http://files.hddguru.com/index.php?acti ... bble%20LT&
PostPosted: February 27th, 2015, 7:40
Do you get 0x4F10 at init ?
Then maybe the solution in ace`s knowledgebase is working.
Digitalsupport
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: February 28th, 2015, 1:33
Yes it gives 0x4F10 at init in ver 5.8 and in UDMA 5.9 it says "SED DRIVE LOCKED"
If i am not mistaken ACE Knowledge base does not have a solution to it yet.
If i have missed it would be glad if someone points it out.
PostPosted: February 28th, 2015, 3:49
they do, working on HOWTO add it
and there are ways not one.
PostPosted: February 28th, 2015, 4:12
Not just firebird, have seen "some" FBlite as well. Unable to check SA.
PostPosted: February 28th, 2015, 8:02
Right.
Faulty heads were the reason for Relo not getting cleared.
Head Replaced resolved.
Thanks all for Support.
Users browsing this forum: Google [Bot], Hardcore Games and 216 guests
