 Post subject: Toshiba MK6465GSXN, no response, plz advise repairer in AU
PostPosted: May 28th, 2015, 1:14
Have a client's hard drive, Toshiba 2.5" MK6465GSXN 640GB unit.
Cannot hear any ping/zing/clicks, it doesn't feel like it's spinning up at all.
What is a recommended clean-room service centre in AU I can send this to for personal photo recovery.
May 28 15:34:10 ctpc001 kernel: [7442502.239227] ata5: exception Emask 0x10 SAct 0x0 SErr 0x40d0002 action 0xe frozen
May 28 15:34:10 ctpc001 kernel: [7442502.239238] ata5: irq_stat 0x00400040, connection status changed
May 28 15:34:10 ctpc001 kernel: [7442502.239249] ata5: SError: { RecovComm PHYRdyChg CommWake 10B8B DevExch }
May 28 15:34:10 ctpc001 kernel: [7442502.239265] ata5: hard resetting link
May 28 15:34:20 ctpc001 kernel: [7442512.260199] ata5: softreset failed (device not ready)
May 28 15:34:20 ctpc001 kernel: [7442512.260212] ata5: hard resetting link
May 28 15:34:30 ctpc001 kernel: [7442522.284203] ata5: softreset failed (device not ready)
May 28 15:34:30 ctpc001 kernel: [7442522.284215] ata5: hard resetting link
May 28 15:34:41 ctpc001 kernel: [7442533.260200] ata5: link is slow to respond, please be patient (ready=0)
May 28 15:35:05 ctpc001 kernel: [7442557.288210] ata5: softreset failed (device not ready)
May 28 15:35:05 ctpc001 kernel: [7442557.288224] ata5: limiting SATA link speed to 1.5 Gbps
May 28 15:35:05 ctpc001 kernel: [7442557.288232] ata5: hard resetting link
May 28 15:35:11 ctpc001 kernel: [7442562.488210] ata5: softreset failed (device not ready)
May 28 15:35:11 ctpc001 kernel: [7442562.488223] ata5: reset failed, giving up
May 28 15:35:11 ctpc001 kernel: [7442562.488235] ata5: EH complete
You have a backup...right? | Tech Repairs on YouTube
 Post subject: Re: Toshiba MK6465GSXN, no response, plz advise repairer in
PostPosted: May 28th, 2015, 1:35
If it's not spinning, then it could be a PCB fault. You could try a PCB swap and firmware transfer.
http://ep.yimg.com/ay/yhst-144375849714 ... -fw-17.gif
Check the fuse near the SATA power connector.
PostPosted: May 28th, 2015, 2:09
Okay, I'll be honest, I'm not sure which component there is going to be a fuse. Best I can see there's a 0603 0R link, which I've checked but it's all good.
Astoundingly, the first drive on my stack of surplus drives was a PCB match for this one!
That said, I'd still be fine to send it off to be repaired instead. While I deal with SMD all the time, I'd feel kind of "safer" handing it off to someone who does HDD's for a living.
File comment: Power / switchmode region of the controller board. Tested the large E1 block (9.5K seems right) and the 0603 0R link closest to the SATA power pins.
File comment: Client drive on left, "spare" drive on right (has slow-read issues, suspect failing amp/head).
PostPosted: May 28th, 2015, 3:02
Here are the voltage test points:
PostPosted: May 28th, 2015, 3:19
Vcore 1.18V
Vio 2.50V
PostPosted: May 28th, 2015, 3:28
inflex wrote:
Vcore 1.18V
Vio 2.50V
Those look OK.
PostPosted: May 28th, 2015, 3:49
inflex wrote:
Vcore 1.18V
Vio 2.50V
Those look OK.
Head stiction? Bearing issues? Maybe time I went looking for a repairer?
PostPosted: May 28th, 2015, 15:39
Hi sent you PM
PostPosted: May 29th, 2015, 11:00
Additionally, better to check voltage on the motor during power on. If it's OK, so sold off ROM IC and read/check it's content. Sometime, it's damaged (for example, zeroed at the whole content address range).
PostPosted: May 29th, 2015, 16:10
+1 HaQue - He's your man in Australia.
PostPosted: May 30th, 2015, 6:18
Have you tried changing the PCB as the Donor drive seen in photo is a PCB Match for your Patient.
If it still does not SPIN it there could be great chances of "Head stiction" as these drives do have this issue.
PostPosted: May 30th, 2015, 22:47
Hi everyone, thanks for the followups. For now I've organised to have it sent off for professional recovery by one of the participants here.
Many thanks.
Users browsing this forum: No registered users and 171 guests
