 Post subject: Seagate ST3500418AS Bad TRANSLATOR
PostPosted: June 17th, 2015, 7:22
I have a SEAGATE ST3500418AS with a bad TRANSLATOR. ( Module 28 ). Rest all modules i have backed up in terminal reading mode. It gives terminal access
I am using PC-3K. Efforts to regen fail it gives LED:000000CC FAddr:0024E2D
Both the copies of 28 are not reading at all.
My question is Could it be due to bad area ?
If yes then is there a way ?
Any hints appreciated.
 Post subject: Re: Seagate ST3500418AS Bad TRANSLATOR
PostPosted: June 17th, 2015, 14:08
What's the P/N of the drive?
I can only guess without the drive on hands, but it looks like heads can't write anymore.
PostPosted: June 17th, 2015, 21:36
Have you tried the "LED:000000CC Fix" in PC-3000? It could be just a simple fix.
PostPosted: June 18th, 2015, 0:51
P/N 9S142-302
Heads unable to write could be the possibility let me try writing check and comeback to you.
If you are referring to SEAGATE F/W Fix then its not working on this drive. That is what i have posted that if i attempt to regen translator it gives the error specified.
Thanks for replies
PostPosted: June 18th, 2015, 4:59
in this case the best is test if Heads can Write, if not you need Heads exchange.
maybe media problmes too.
good luck
 Post subject: Seagate LED CC fix / translator regeneration
PostPosted: June 18th, 2015, 19:10
Roughly speaking, it's SA backup, SMART clean-up and translator rebuild, so there's not much difference.
But none will work if both copies of mod 28 are unreadable.
PostPosted: July 6th, 2015, 6:47
good luck
Sorry it took me long.
Tried replacing new heads in this drive but the problem remains the same.
The heads of patient works fine in Donor
Any Hopes ?
PostPosted: July 6th, 2015, 12:23
Can you read mod 28 with read continue option? Maybe is possible to 'patch' errors inside this file and write back. You can ignore read errors when reading system file for this, 3,028,0
PostPosted: July 8th, 2015, 0:40
Thanks HDDGUY
PC3k does not have option of reading with erros.
Is there a command to read it with errors ?
Users browsing this forum: No registered users and 187 guests
