 Post subject: HTS723232A7A364 issue.
PostPosted: July 2nd, 2015, 16:00
Hello!
As in topic : Hitachi : HTS723232A7A364 320 GB after heads replacement no detection.
The drive becomes ready but detection fail.
NV RAM is OK
PCB Tested OK
Heads tested on another drive OK
Any thoughts ?
Thanks in advance.
 Post subject: Re: HTS723232A7A364 issue.
PostPosted: July 2nd, 2015, 16:07
You have pc3000 UDMA or express?
PostPosted: July 2nd, 2015, 16:16
MRT PRO.
Don't have UDMA yet.
PostPosted: July 2nd, 2015, 16:23
Dunno about MRT, but in pc3k I would enter the Hitachi ARM utility and manually select the family.
It should then initialise the drive and give ID, allowing you to work with the SA.
PostPosted: July 2nd, 2015, 16:26
I tried this on MRT and manually selected the correct family but it didn't work.
PostPosted: July 2nd, 2015, 18:20
Provided it is able to load a minimal set of modules. And the load process is kindof braindead, it needs to be able to load those modules from either copy, but all of them must be intact, while not all of them would be neccessary for sa access.
PostPosted: July 2nd, 2015, 18:51
I can see clearly a scratches to the outer diameter on the top side of the platter.
scratches to SA meaning GAME OVER ?
PostPosted: July 2nd, 2015, 18:56
only three modules : RPSH, USAG and MFGP read successfully
PostPosted: July 3rd, 2015, 3:18
That's not that much...
Especially if we consider the drive must have been able to load more modules if u were able to access the SA.
PostPosted: July 13th, 2015, 16:48
Update :
Customer told me that the IT technician in his company replaced PCBs :)
After he gave me the original PCB the drive not ID also but after re-identify the drive in MRT read the full model and capacity. Scanning the drive shows a lot of delayed sectors and error sectors.
DE can't identify the drive.
Any thoughts?
PostPosted: July 14th, 2015, 4:59
Were these read with foreign PCB :o
that's odd
PostPosted: July 14th, 2015, 12:10
Yes.
PostPosted: July 15th, 2015, 3:03
It can't be true
PostPosted: July 15th, 2015, 14:13
True or false, that's what happened already.
Why should I lie ?
PostPosted: July 15th, 2015, 16:36
I see a couple of reasons for saying it is impossible as well, but i believe what you say.
If the pcb is not native, it might have visited another firm where anything might have happened to it. Having some insight on the boot process of these drives, i would have expected a bunch of modules to be readable, because if they are not readable, the there's no sa access at all, u get abrt to each command accessing the surface.
PostPosted: July 15th, 2015, 18:00
Thank you very much Mr.Pepe for valuable informations.
Case Solved :)
Virtual Translator :)
Data is copying now. :)
PostPosted: July 16th, 2015, 3:20
what about the scratches you wrote above ? :roll:
PostPosted: July 16th, 2015, 7:13
Fortunately, data needed was some files ( approx. 350 MB ). And I got them all without even one error :D .
Don't even think I am lying. Because I don't have to. :D
Users browsing this forum: Bing [Bot] and 286 guests
