 Post subject: WD My Book Essential 2TB possibly dead, please help
PostPosted: July 22nd, 2015, 21:39
Some research shows that these drives have a common failure in the controller board, trying to figure out if I'm on the right track before I waste money on a replacement board or just scrap the drive and the data.
If I power cycle the drive, it works fine briefly, before throwing out input/output errors, and then finally not being recognized by my Arch Linux box. Process repeats if I power cycle the drive. I haven't heard any weird clicking behaviour from the drive (at least that I've noticed)
What's your vote, drive or controller? Thank you!
 Post subject: Re: WD My Book Essential 2TB possibly dead, please help
PostPosted: July 23rd, 2015, 2:06
Probably some media issues (bad sectors)
PostPosted: July 23rd, 2015, 9:35
not a controller problem for sure.
it could be bad sectors, FW or even 1/2 weak heads.
Data Recovery Pakistan
PostPosted: July 23rd, 2015, 11:31
IMO dont waste money on the PCB. Unlikely to be the culprit. You have a bit if functionality - check SMART.
My books depending on year of manufacturing use different drive families. Saddle G6 notorious for losing head(s). Dragonfly and Diablo mostly service area problems.
PostPosted: July 23rd, 2015, 22:32
Thanks for the advice!
Since the drive is half alive (at least for periods of time), any suggestions for how to get some of the data off it?
PostPosted: July 24th, 2015, 5:31
Try ddrescue. Since this is probably a one-off chance, consider using the services of a local Data Recovery Lab to ensure your data's safety.
PostPosted: July 24th, 2015, 15:33
Agree, if it's no big deal if you lose the data then give ddrescue a shot to clone the drive to a known good one,
If the data is important then better to secure the services of a DR lab, it shouldn't be expensive at this stage.
PostPosted: July 24th, 2015, 16:43
If your data is worth my minimum price of $350 for a 2TB drive and you can get it to Guelph, I'd be happy to look at it for you.
PostPosted: July 24th, 2015, 17:49
At the very least, examine the SMART report with smartmontools or similar. This will confirm whether the drive itself has physical problems or whether there is a problem with the enclosure or cabling (unlikely).
Users browsing this forum: No registered users and 42 guests
