 Post subject: seagate barracuda 2tb FRIED
PostPosted: October 4th, 2015, 13:18
I connected the power the wrong way or something and the result after a lot of digging is a fried +5 tvs diode. I removed the diode to see if this was a miracle cure, but nothing. I was gonna move on to the +12v diode but thought better.
onepcbsolution....seem to be able to software fix firmware swap. $45.
hdd-parts........do a hardware soldiering swap. $45
Both above are partner firms.
I have encountered "fzabkar" and his knowledge. Which is why i removed the diode, should i have done something else like wire up to power?
What i would like to find out is if having matched;
1. Model# ST2000DM001
2. Board# 100717520
3. F/W# CC27
Would i then using a CP2102 usb to hd connector via puTTy be able to tranfer firmware bios?
Any input would be appreciated.
 Post subject: Re: seagate barracuda 2tb FRIED
PostPosted: October 4th, 2015, 15:52
A photo of pcb would help to advise
No,
you need a programmer or swap ROM.
PostPosted: October 4th, 2015, 15:57
Measure the zero-ohm resistors. The 5V pair will be open circuit.
http://www.users.on.net/~fzabkar/HDD/ST ... 01_TVS.jpg
Also measure the voltages at the SATA power pins. If you have been swapping cables between different PSUs "or something", then there is a real possibility that there will be 12V on the 5V pins.
http://pinouts.ru/Power/sata-power_pinout.shtml
PostPosted: October 5th, 2015, 5:36
Photo is as fzabkar posted without 5v TVS.
I will have to get hold of `voltmeter` and `magnifying glass` for test.
colanco "you need a programmer or swap ROM."
programmer??? Is not a `USB 2.0 to TTL UART 5PIN CP2102 Module Serial Connector` via puTTy a programmer
swap ROM means this bios to a donor board. Yes?
fzabkar "there will be 12V on the 5V pins" you mean 12v stored in there via capacitors.
Sorry for lack of comprehension.
Electronics not a strong point.
Last edited by asktheaudience on October 5th, 2015, 5:47, edited 2 times in total.
PostPosted: October 5th, 2015, 5:42
open circuit -
An electric circuit through which current cannot flow because the path is broken or interrupted by an opening.
Got that one.
PostPosted: October 5th, 2015, 6:34
No,if you do not have tools ( PC3K , MRT ... )
Users browsing this forum: Google [Bot] and 81 guests
