Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: wd800jd-75msa3 head swap
PostPosted: November 17th, 2015, 6:55
hello everyone how are you ?
wd800jd-75msa3 need data
drive have clicking.. drive ahve 2 head i off 1 head with wdr drive come on ready so i am trying it means drive head 0 is gone so i have perfectly change head after change perfect again drive same clicks same style on clicks.. so i was going tu again of head 0 drive come ready but the problem drive show abort eror on mhdd and victoria.
so i can change head again on perfect drive but same same problem again drive click on again with same style i dont know why 0 head is click can anyone please suggest what can i do for drive come ready with both head ..
Thankss in advance
sorry for my english i am not native speaker
 Post subject: Re: wd800jd-75msa3 head swap
PostPosted: November 17th, 2015, 7:32
thanks spildit for you answer can u please tell me which module is corrupt i can write on drive and drive come to ready beacause i check module in wdr its all working well on good
PostPosted: November 17th, 2015, 10:16
@spildit and expert please watch this video and i hope you will understand my problems thanks
PostPosted: November 17th, 2015, 10:17
please watch this video thanks
https://www.facebook.com/hard.recover.3 ... _processed
PostPosted: November 17th, 2015, 10:36
On family Unicorn
Donor heads are selected very badly.
Sometimes you need to pick up dozens of donors compatible head.
Most often used to read each head separately with hot swap.
PostPosted: November 17th, 2015, 10:42
how to read each head speratly kindly please tell me or guide me please i will be very thanks full for yours @tomset
PostPosted: November 17th, 2015, 11:23
To read by each head, you need at least PC3000 + DE.
You have?
PostPosted: November 17th, 2015, 11:30
no idont have i just using r studio ddrescue for cloning
PostPosted: November 17th, 2015, 11:42
You torment to do so.
Heads read turns every surface.
Approximately 50-100 megabytes on one and then on the other
PostPosted: November 17th, 2015, 19:26
Tomset wrote:
On family Unicorn
+1
apart from what's already been said, i bet PCB is bad and servo + data is killed on the bottom side.
If u put the donor MHA back to donor, and it does not click, i am pretty close to the truth.
Tomset: with right technique u would not need several donors.
PostPosted: November 17th, 2015, 19:30
What are you talking about?
Tomset wants to say that case where you think servo is gone from one side platter - is not really gone, but you need very picky head donor.
PostPosted: November 17th, 2015, 20:40
He wasn't talking about the case when the servo is gone, just a plain head swap on older wd drives.
When the servo and data is damaged by the bad pcb, it is not very easy and usually only a fraction of the data is recoverable.
PostPosted: November 18th, 2015, 4:29
drHDD,
That's what I thought while I was young. :)
But the reason for - not compatible head.
No case was not, except gashes.
Always after a long selection of the donor, it was possible to read data.
There were cases when the donor had to pick up within two years.
PostPosted: November 18th, 2015, 5:28
I know what you are talking about, but believe me, it does not have to be like that.
It is because most DR people has no idea what the cause of the so called incompatibility is.
This was why i liked WD, coz very few liked them because of this behaviour.
PostPosted: November 18th, 2015, 8:01
pepe,
It would be interesting to hear your theory.
As far as I know, all the stupid pick a compatible donor.
Nor any adjustment of adaptive parameters not help.
PostPosted: November 18th, 2015, 11:06
i bet it would be interesting :)
the solution even more interesting... ;)
PostPosted: November 18th, 2015, 11:18
DCM matters on Unicorn.
So does the zenith of the HSA spindle, and by extension, the top lid position.
If you can't get the data with a maximum of 3 donors, then the drive is toast; you are doing something wrong; or you do not know what to do.
http://www.datasaversllc.com
PostPosted: November 18th, 2015, 11:34
jono-ats,
DCM has very little relation to the compatibility of the donor.
This code parts manufacturers.
But no parameters, configuration card, switch, or adaptive parameters heads.
In general, the top of all HDD, very few labels to properly to compatibility.
Besides family, the rest only increase the likelihood, but does not guarantee it.
PostPosted: November 18th, 2015, 11:37
pepe,
Obviously, you do not know either.
And I can shoot the breeze. :)
Users browsing this forum: Google [Bot] and 237 guests
