 Post subject: Samsung ST1000LM024 disk replacement
PostPosted: November 22nd, 2015, 10:56
Hi everybody,
Can I buy a new drive and switch disks in order to recover the data? My problem is that my external SSD is not detected at all (I guess it must be a card/software problem)
 Post subject: Re: Samsung ST1000LM024 disk replacement
PostPosted: November 22nd, 2015, 14:38
Hello luispi
First of all. Before you make any further steps it is to determine how important the data is to you. There are many DIY steps that could do harm to your hard drive.
The ST1000LM024 is a common hard drive. (spinning platters).... I'm not sure what you mean by external SSD. An SSD is a data storing device without any mechanical parts. (ssd = solid (not spinning :-) state disk
Maybe you have an external USB-Harddrive and opened it and found the ST1000LM024 inside? An then what have you done then?
In the end I think it could have been an oversurge... some fuses/diodes that could be defective... but thats only a guess...
Maybe you could give more information what exactly you have done?
Greetings
Benjamin
Fachwerkstatt für Data Recovery / Datenrettung in Stuttgart - Riedel IT - Ameisenbergstraße 30 - 70188 Stuttgart
PostPosted: November 22nd, 2015, 20:05
Hi Benjamin, thanks for your prompt reply.
First, the data I'm trying to recover is not critical, therefore I figure I would risk trying to recover it and at the same time learn something in the process.
Regarding what I've done with my backup HDD, I realize I did not explain myself right and wrote some misleading information, so I'll try again:
I have a dead (not recognized at all in 3 different laptops with 2 different USB cables) Seagate Backup Plus 1 TB Hard Drive. After looking around I found a couple of DIY videos for diagnosing and repairing and ultimately decided to tear it appart. Inside I found a Samsung Spinpoint Momentus HDD model ST1000LM024. I went further and opened up the HDD case trying to verify if there was a stuck head and found out they were OK. After many unsuccessful tests, my conclusion is that the problem is the PCB board (or . At this point, I am in the market for a new external HDD backup drive and found some combos that offer annual cloud storage when buying a physical unit, so i figured I'd buy a similar unit and try to switch the disk in order to recover the data from my present drive. I realize I might end up with two defective drives but am wiling to take the risk.
I hope this clears a bit my original posting and again, thanks for yr help.
PostPosted: November 23rd, 2015, 4:20
Switching the disks will NOT help you.
PostPosted: November 23rd, 2015, 4:57
Instead of watching stupid DIY-videos you should have read something useful, e.g.:
https://en.wikipedia.org/wiki/Flying_height
https://en.wikipedia.org/wiki/Disk_read-and-write_head
This tells you why you should not open a drive outside a clean room: "In modern drives, the flying height is normally about 3 nanometers. Thus, the head can collide with even an obstruction as thin as a fingerprint or a particle of smoke."
A platter swap is not a "risk", it will lead to 100% data loss for sure. First step is proper diagnose: What happened to the drive, did it spin in the first stage? Did you power it on opened?
best regards,
PostPosted: November 23rd, 2015, 6:03
Hello luispi,
That is not testing! ;-) You killed or you almost killed the patient! edit: yes you could be on the right trail...
There are very good information by the others. Please study intensely first before you make any further steps.
Benjamin
PostPosted: November 23rd, 2015, 10:43
Well,
If The HDD Was Spinning How Could it Have Head Stuck
Users browsing this forum: Doomer, Google [Bot] and 60 guests
