 Post subject: Drive Capacity Incorrect
PostPosted: December 29th, 2015, 4:40
I have a brand new 8 TB hard drive that is reporting as only 3.86 GB in Disk Management. Obviously, I could send the drive back, but is there any fixing it as an alternative? Just checking... Thank you in advance.
File comment: Bottom one in Disk Management
 Post subject: Re: Drive Capacity Incorrect
PostPosted: December 29th, 2015, 5:15
Have you bought it from a reliable source? Maybe it is just a fake.
Those who know don’t talk. Those who talk don’t know.
PostPosted: December 29th, 2015, 5:16
I bought it from Amazon where Amazon was the actual seller, I believe.
PostPosted: December 29th, 2015, 5:56
Try the following in command prompt under administrator.
Type “diskpart” after the command prompt to start the Disk Partition utility. This should result in a DISKPART command prompt.
Type each of the following commands, one at a time, after the DISKPART prompt, pressing “Enter” after each:
list disk
select disk # (select the disk number that shows 3.86GB as capacity)
clean
create partition primary
select partition 1
active
format FS=NTFS (this will take sometime)
assign
exit
The disk should be back to full capacity. If not then i would send it back as its probably a fake.
Web: https://www.day1data.de
PostPosted: December 29th, 2015, 7:22
If you right click where it says "not initialized" and select properties, what model no. is shown?
PostPosted: December 29th, 2015, 17:53
Doesn't the symptom reflect a problem with SA access? Isn't this what you see if you remove the PCB and access it on its own?
Does the drive spin up? Any bad noises?
PostPosted: December 30th, 2015, 3:30
3.86GB... Is it a Seagate? ;)
PostPosted: December 30th, 2015, 4:19
Exactly so, looks like DOA
http://www.rescue-it.se
Users browsing this forum: Google [Bot], melvin and 56 guests
