 Post subject: Seagate not coming to terminal
PostPosted: January 22nd, 2016, 8:18
There are several posts and information for this typical symptoms ,but still I would like to know more --
Seagate Barracuda FW KC45 , Disk stays busy & does not come to terminal.
After isolating HDA it gives following terminal -
Boot 0x10M
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF
ResponseFrame 2EA0 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
I have tried to short read channel but not getting success.
Now I want to know whether this could be because of any other reason like --
1) PCB non native
2) PCB issue,
can someone pls. help
 Post subject: Re: Seagate not coming to terminal
PostPosted: January 22nd, 2016, 8:27
What kind of sounds are coming from the drive.
Does it continue to spin or spin down?
Web: https://www.day1data.de
PostPosted: January 22nd, 2016, 8:33
hi day1data
Thanks.
it spins normally no abnormal sounds nor it spins down as well.
PostPosted: January 22nd, 2016, 10:33
Check Serial Number from rom content (External Programmer) and compare S/N in lable ( I had faced this many times)
PostPosted: January 24th, 2016, 10:10
Hi gps31
Thanks. I was about to do the same ,but before that customer took disk back due to long delay from my side. Tragic end to this case :(
PostPosted: May 23rd, 2016, 11:57
Dear Sir
HDD Sping Possible
Other Way noot Sping Not Possibles
Raminfotech Data Recovery
Chennai's No.1 Data Recovery Center
http://www.raminfotechdatarecovery.com
skp:raminfotech.vijayan
PostPosted: May 26th, 2016, 9:42
this case
1 check pcb
2. hdd sping ? rom or pcb problem
3. most this error hdd head problem 10% only rom problem
any ? call 9841983643 raminfotechdatarecovery.com
PostPosted: May 28th, 2016, 1:51
Banned User
Boot 0x10M
Spin Up
1) PCB non native
2) PCB issue,
check your work with ROM and PCB
find 1 PCB code used to work and move ROM to
Users browsing this forum: quinkq and 260 guests
