 Post subject: Seagate Barracuda LP 2TB
PostPosted: February 28th, 2016, 14:02
Ok, this drive died recently and I would like to move as much as possible before tossing it.
It spins up fine and hums nicely but Windows 10 just doesn't like it.
When I go into DOS (CMD as admin), I can see all my files and directory structures but I cannot copy or move anything to another disk. As you can tell from my xcopy attempt below 99.99% of my data was NOT moved.
Any ideas?
C:\WINDOWS\system32>n:
N:\>dir
Volume in drive N is 6.  Seagate1
Volume Serial Number is A404-D26B
Directory of N:\
12/23/2015  11:08 PM    <DIR>          Google Drive
06/03/2014  09:01 AM    <DIR>          Movies
06/03/2014  09:11 AM    <DIR>          Music Videos
10/04/2011  10:30 AM    <DIR>          TV Shows
02/14/2012  02:48 PM    <DIR>          xbmciso
               0 File(s)              0 bytes
               5 Dir(s)  215,306,993,664 bytes free
N:\>xcopy n: m: /s/e/r/c/h/k/o/x/y
File creation error - The request could not be performed because of an I/O device error.
Unable to create directory - M:\$RECYCLE.BIN
The device is not ready.
File creation error - The device is not ready.
Unable to create directory - M:\Movies
Unable to create directory - M:\Music Videos
N:System Volume Information\IndexerVolumeGuid
Access denied
N:System Volume Information\tracking.log
N:System Volume Information\Chkdsk\Chkdsk20130418153154.log
N:System Volume Information\Chkdsk\Chkdsk20130427133105.log
N:System Volume Information\Chkdsk\Chkdsk20130427133259.log
N:System Volume Information\Chkdsk\Chkdsk20150726011113.log
N:System Volume Information\EfaSIDat\SYMEFA.DB
Access denied
N:xbmciso\WTP1NNE1\type.Movies
N:xbmciso\WTP1NNE1\type.Music Videos
N:xbmciso\WTP1NNE1\type.TV Shows
N:xbmciso\WTP1NNE1\WTP1NNE1.iso
File creation error - Data error (cyclic redundancy check).
N:xbmciso\WTP1NNE1\xbmciso.log
8 File(s) copied
N:\>
 Post subject: Re: Seagate Barracuda LP 2TB
PostPosted: February 28th, 2016, 14:36
I don't get it
your problem is with the source drive (n) or with the destination drive (m) ?
PostPosted: February 28th, 2016, 14:47
The source drive (n). The destination drive (m) is brand new.
PostPosted: February 28th, 2016, 15:10
But IIUC the error "Unable to create directory" is referring to the destination drive (m)
PostPosted: February 28th, 2016, 16:19
It is strange. Now, I can't do a directory of all the subfolders in (n). I had another drive which "went bad" too and I find it too coincidental that I never had a problem with my 8 drives for 3-4 years until, all of a sudden two drives disappeared when I upgraded to Windows 10.
PostPosted: February 28th, 2016, 17:35
Work with the drive outside the Win environment. Check SMART, check mechanics via software with something like MHDD, and so on.
PostPosted: February 28th, 2016, 18:25
Do you have more details on how I can work on these drives outside of the windows environment?
PostPosted: February 28th, 2016, 18:46
Try mounting the drives from a Ubuntu Live CD.
SMART tools include CrystalDiskInfo (Windows) or smartmontools (Linux). Look for reallocated, pending, or uncorrectable sectors.
PostPosted: February 29th, 2016, 17:01
I was able to see the entire directory structure of my "bad" Seagate 2TB HDD from UBUNTU! The "partitions" looks a bit weird though when compared to other HDDs on my system. It showed 4 partitions, 2 of which were both 2TB in size.
Only one of those 2TB partitions was accessible via ubuntu and, from there, I was able to "see" a listing of all files and directories but I was unable to move those files to another disk due to some sort of splice error. When I try to copy similarly sized files from 2 other HDDs, it works fine. So, something is wrong with this particular disks partition table or something?
I'm not sure what to do next actually...
PostPosted: February 29th, 2016, 17:14
Could we see the partitions in a disc editor, eg DMDE (freeware)?
http://dmde.com/
PostPosted: February 29th, 2016, 21:39
Hmmmm... do you mean, from Windows? I'm not sure that will work because Windows can't see this drive as well as ubuntu. When I google DMDE, I only see a windows download.
PostPosted: March 1st, 2016, 14:02
DMDE is a disc editor. A drive does not need to be mounted in order for DMDE to work with it. In fact it is often better that the OS does not mount it.
PostPosted: March 1st, 2016, 14:53
That makes sense but I'm not sure how to go about it then.
If I download the Windows version, how do I stop windows from mounting the drive before I run DMDE?
Should I run DMDE under ubuntu? If so, do I download that "linux" version or something else?
PostPosted: March 2nd, 2016, 2:10
Just run DMDE under Windows and show us the Partitions window.
If you wish to prevent Windows from mounting the volumes, then click the MBR On/Off button. This will invalidate the 55 AA signature at the end of sector 0.
PostPosted: March 2nd, 2016, 10:09
see attached
PostPosted: March 2nd, 2016, 10:23
That's LBA 9. We need to see LBA 0.
If you select Mode-> Hex/Text, you will probably see that LBA 9 is filled with "BAD ".
PostPosted: March 2nd, 2016, 13:56
they all are actually
PostPosted: March 2nd, 2016, 14:24
actually what ? the same ? (do you use a translator ?)
PostPosted: March 2nd, 2016, 22:01
fzabkar, LBA:0 is EXACTLY the same as LBA:9 ... also in Hex mode, everysingle line (thousands and thousands of them all say "BAD BAD BAD BAD" at the end.
PostPosted: March 2nd, 2016, 22:26
Can you connect the drive to a SATA port rather than a USB-SATA bridge?
Can you see the SMART data?
Users browsing this forum: No registered users and 63 guests
