 Post subject: Help me in Raid Case ...
PostPosted: April 14th, 2016, 15:52
Hi All
First ... i have Raid 6 case .. I DID RAID configuration able to see the partition and 6 tb off data .. but there is some folder empty .. the client said there is files in this folders .... is it possible to get 6 tb off data all is working fine -- but there is folders is empty .. ?
why it can be happen ? where is the problem here ?!
second : can someone direct me how to lean more in raid recovery ? if there is good pages or info at internet please provide it for me .. if not here please PM me .. even it's not freei will pay for it >>
i am waiting you all
thanks
 Post subject: Re: Help me in Raid Case ...
PostPosted: April 14th, 2016, 16:11
Got more details about the RAID than that it is RAID 6? Is it a software or hardware RAID? What kind of system was it in? What is the file system? What happened that makes recovery necessary?
PostPosted: April 14th, 2016, 16:32
Hi, lcoughey,
this is Buffalo nas storage ... 8 HDD .. 2 drives is damage so i use the 6 and reconfigure it as raid 6 ... i found the partition XFS -- 6 tb off data i saved and it's working fine but i found some folder empty .. the client said that .. there is more files ... if i do wrong raid configer how can i get 6 tb off data and the data is working !
 Post subject: Re: Help me in Raid recovery
PostPosted: April 14th, 2016, 18:49
H13 wrote:
i have Raid 6 case .. I DID RAID configuration able to see the partition and 6 tb off data .. but...
If necessary, we'll be happy to help with this recovery remotely.
PostPosted: April 15th, 2016, 5:26
What sw tool has been used to access data on XFS ? Are those recovered files in good condition? It seems something additionally wrong with file system or with SW you are using. I can try to help remotely.
Angel Data Recovery
PostPosted: April 15th, 2016, 6:52
Interesting issue which I'm facing as well.
the largest file size i got is a 1GB working well zip file.
So i suppose my parameters for recovering the raid is correct.
PostPosted: April 15th, 2016, 7:01
Congrats
PostPosted: April 15th, 2016, 7:25
i use ufsexplorer and the files working fine ... even big files like pst .. working
i believe there is something wrong ...
this is : TeraStation III TS-8VHL
8X3 tb HDDs .. 2 is damaged .. i us usf to access data .. raid6 ..
thanks dr for your help
thanks demitry for your help
terryhoho ? you face same problem ?
jermy .. thanks too
waiting for your helps eng ..
PostPosted: April 15th, 2016, 7:42
jermy .. thanks too
yeah same problem. managed to get a lot files out in perfect shape.
what have the 2 experts tried to help you on?
PostPosted: April 15th, 2016, 10:34
H13 wrote:
jermy .. thanks too
IMHO he says that he managed to recover everything successfully.
PostPosted: April 17th, 2016, 23:15
jermy wrote:
H13 wrote:
jermy .. thanks too
No, I recovered most of the things, including 1GB working zip file. So i assume the parameter is correcet.
but some files were not recovered, which includes corrupted files small as less than 1MB excel file, pictures, and missing file in folders
PostPosted: April 18th, 2016, 9:49
My suspension is you have the RAID6 assembled in UFSexplorer using a drive that dropped out of the RAID some time ago. Since the TeraStation uses Linux Software RAID aka mdadm you can look at the meta-data from each member drive using Linux. For example the below is from a remote TeraStation recovery I performed in the past. Note the Events count and Update Times should be in sync for all RAID member drives. In any case you may want to assemble the RAID using Linux mdadm to check if Linux can see your missing files. If you need additional help I am happy to provide remote assistance.
% mdadm -E /dev/sdb6
/dev/sdb6:
          Magic : a92b4efc
        Version : 0.90.00
           UUID : 78a5fba6:5739f38b:d32f4eec:161692a6
  Creation Time : Wed Nov 30 09:18:49 2011
     Raid Level : raid5
  Used Dev Size : 961749888 (917.20 GiB 984.83 GB)
     Array Size : 2885249664 (2751.59 GiB 2954.50 GB)
   Raid Devices : 4
  Total Devices : 2
Preferred Minor : 2
    Update Time : Mon Dec 15 10:31:42 2014
          State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 2
  Spare Devices : 0
       Checksum : 3f4e411d - correct
         Events : 2238388
         Layout : left-symmetric
     Chunk Size : 64K
      Number   Major   Minor   RaidDevice State
this     1       8       22        1      active sync   /dev/sdb6
   0     0       8        6        0      active sync   /dev/sda6
   1     1       8       22        1      active sync   /dev/sdb6
   2     2       0        0        2      faulty removed
   3     3       0        0        3      faulty removed
On-Line Data Recovery Consultant. RAID / NAS / Linux Specialist.
Serving clients worldwide since 2011
FreeDataRecovery.us
PostPosted: April 20th, 2016, 7:20
Maybe one of RAID mamber is invalid and you have to disable it and recover data from XOR or RS blocks.
Also some XFS prtitions have 1024 sector size, try to look into empty folders with these parameters.
