 Post subject: Seagate ST31000524AS , 7200.12 not deducted
PostPosted: June 13th, 2016, 12:50
Friends/Experts , please help me to get my Seagate ST31000524AS back. I tried Self Healing commands at F3 6> level. All batch file passed except B21. Please help.
 Post subject: Re: Seagate ST31000524AS , 7200.12 not deducted
PostPosted: June 13th, 2016, 13:46
What may have led to drive failure? Anything out of the norm?
What was the drive's behavior, physical and logical, if any, PRIOR to doing anything with it?
PostPosted: June 16th, 2016, 9:30
Thank you for your reply. When I start the computer my HDD drive starts to spin and it gives some
(may be 10 or so)clicking sound and goes salient. I am having RS232 terminal connector. I can access F3 T> terminal point.
i have tried ctrl+Z . It spins down. But ctrl+U gives error.
You can give me step by step instruction. I"ll try it and post the result .
PostPosted: June 16th, 2016, 10:16
Sometimes could be a firmware issue, but most frequently it is a heads issue.
Just post the terminal upon issuing the "U" command.
PostPosted: June 18th, 2016, 12:01
ASCII Diag mode
F3 T>/2
F3 2>Z
HighPowerMode
Spin Down Complete
Elapsed Time 0.086 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
DiagError 00006008
Spin Error
Elapsed Time 13.748 secs
R/W Status 2 R/W Error 84150180
F3 2>
some time i get this error message.
PostPosted: June 18th, 2016, 15:26
Looks like mechanical problem
PostPosted: June 18th, 2016, 17:21
DiagError 00006008
this error mean : Spin Up Failed
this Refer To Mechanical problem there
you run B level this mean data is not important for you
if you need online help PM me i will check this case by TV
http://www.hpwlab.com
Users browsing this forum: Google [Bot] and 238 guests
