Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Seagate Barracuda ST2000DM001 1CH164-510 fw cc27 problem
PostPosted: August 2nd, 2016, 11:25
drHDD wrote:
Price for this case is $2000.
That means your charging 45c per hour. Now thats a bargain :shock:
PostPosted: August 3rd, 2016, 17:11
labtech wrote:
Connect terminal and just power on. No need to issue commands for terminal output.
I started the terminal using putty, and I receiving as you can see in the pictures, a nonsense output.
I don't know if the cables or because I don't use a proper TTL-USB adaptor could be the problem.
PostPosted: August 3rd, 2016, 17:35
Select a baud rate of 38400 bps.
PostPosted: August 3rd, 2016, 17:43
Configuration from putty:
Speed: 38400
Data bits: 8
Stop bits: 1
Parity: None
Flow control: None
PostPosted: August 3rd, 2016, 18:36
Have you followed the correct pinout?
http://www.kepmegosztas.com/img/b2e415fdc539c3e16732a0a5c4e24288/seagateconnector_pinout.jpg
PostPosted: August 3rd, 2016, 18:55
Also measure the voltages at the Tx and Rx pins, both at the HDD and at the adapter.
PostPosted: August 3rd, 2016, 21:46
I may be wrong, but from the picture, the cable you have isn´t a USB-> RS232 cable, that is, one for "creating" a serial port in a computer without one ?
If that is the case, you should not connect the hdd direct to that cable, but would need another adapter to do the conversion from TTL<->RS232 ( a MAX3232 kind of circuit )
PostPosted: August 4th, 2016, 18:21
I'll buy this one if it is doing my job.
http://www.ebay.co.uk/itm/CP2102-USB-2- ... SwNsdXTYsO
Thank you !!!
PostPosted: August 4th, 2016, 18:50
Could you tell me please if this one is ok for what I need:
Thank you
PostPosted: August 4th, 2016, 20:16
sorry for double post
PostPosted: August 4th, 2016, 20:17
I just ordered
http://www.ebay.co.uk/itm/USB-to-TTL-UA ... Sw~OdVayDY
I hope it will be ok
PostPosted: August 5th, 2016, 19:02
It should be. At worst, you will have to adapt it to 1.8V
PostPosted: August 8th, 2016, 6:29
I've just received my TTL to USB adaptor and this is the info from terminal
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0019
(P) SATA Reset
after I pressed CTRL+Z
ASCII Diag mode
F3 T>
What should I do next, please.
Thank you
PostPosted: August 8th, 2016, 11:24
Press CTRL + X and paste the output here.
PostPosted: August 8th, 2016, 17:07
I have tried CTRL + X but it wasn't doing anything.
I have pressed CTRL + Z and after CTRL + X. Please find the file attached to see the output from terminal.
CTRL+X.txt [6.03 KiB]
Downloaded 1723 times
PostPosted: August 8th, 2016, 19:32
Looks fine so far.
And then: /7
X
PostPosted: August 9th, 2016, 15:52
labtech wrote:
Looks fine so far.
And then: /7
X
ok
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:0016
(P) SATA Reset
ASCII Diag mode
F3 T>/7
F3 7>X
Head 00 Resistance 0111
Head 01 Resistance 0140
Head 02 Resistance 015B
Head 03 Resistance 0101
F3 7>
Could you please help me with the next steps ...
Thank you very much for your time.
PostPosted: August 10th, 2016, 6:34
Heads 1 & 2 seem weak. More than likely they are failing. Besides that, bad sectors have more than likely built up triggering firmware issues.
In short, the drive is very unstable and only a specialist IMHO will be able to do the job properly. Hopefully it is not too late. Need to keep it powered off.
Pcimage is highly recommended.
PostPosted: August 10th, 2016, 7:54
The HDD is all the time powered off.
I will receive the new 2Tb HDD WD Black Performance. It is possible to copy/clone data from the faulty one to the new one?
I've see some other cases resolved on the forum using the terminal commands.
Please help me with any advice that I can try at home.
Thank you for your support.
PostPosted: August 10th, 2016, 8:37
If the heads are failing, how can read (copy/clone is a read operation) data? Analogous, if a person eyes are building cataracts, can they read a book well? No, need surgery to remove the cataracts.
I advised in your best interest. I had nothing to gain from my suggestion. Pcimage won't pay me an affiliate commission or something, hahahaaa. Matter of fact, I lost time thinking about what to suggest and post to help in your (drive's) best interest.
Good luck.
Users browsing this forum: Google [Bot] and 100 guests
