 Post subject: 50P flatcable needed with a COMAX E187825 FC-50P connector.
PostPosted: August 16th, 2016, 18:31
I need this flabcable. It is broken inside.
http://myalbum.com/albums/sJej9B4bqUOX
On the connector is written COMAX E187825 FC-50P.
Length is plm 10 centimeter.
The other end is a soldered connector to a board.
 Post subject: Re: 50P flatcable needed with a COMAX E187825 FC-50P connect
PostPosted: August 16th, 2016, 23:02
Is it this one ?
Or you can DIY, buy this cable, cut it (10CM) solder one side
PostPosted: August 17th, 2016, 5:19
Sorry, I made a mistake with the link, the ccorrect link is:
if a moderator edits it in the first post it's ok by me, this message can then be deleted.
Maybe it's a SCSI cable.
PostPosted: August 17th, 2016, 5:56
Moderator, sorry, I made the same mistake again.
This is finally the working link:
http://myalbum.com/album/sJej9B4bqUOX
Forget/delete the last post (not this one).
I think I need a female SCSI crimp connector, I see them in the USA, but $19,50 shipping costs is too steep. So I'm looking for a European/Asian female scsi crimp connector.
PostPosted: August 17th, 2016, 7:05
Its the same link
PostPosted: August 17th, 2016, 7:21
You are right Jermy. If you delete the "s" in "albums" you will have a working link. I send an improvement message but it had to be moderated.
PostPosted: August 17th, 2016, 8:34
OK, I already managed to see those pictures yesterday, and my first reply:
jermy wrote:
Is it this one ?
Stands, nothing has been changed
PostPosted: August 17th, 2016, 9:17
check this link
http://www.cablesonline.com/50pin2lainri.html
PostPosted: August 17th, 2016, 9:18
and this one
http://www.circuitsonline.net/forum/view/133301
Users browsing this forum: elbote83, pepe and 77 guests
