 Post subject: Seagte Hdd Eeprom Chip Failed
PostPosted: November 7th, 2016, 12:05
Recived The Hdd When 5v Diod Failure..
i Am Replced 5v Diod Result : No Power
Pcb Swap With Same Model, Firmware, Part Number Result : Power On , 5 Beeps , power Off ( Forgot EEporm Chip Swap)
Eeprom Chip Swaped Result : No Power
Swap Another Working Board With Same Way And EEpropm Also And Finaly :p ( Result - No Power )
Without EEprom Chip Swap Spinup ANd Spindown
When Swaped EEprom Chip , Hdd Goes Dead ...
That's why I Am telling EEprom Chip failed ,,
What can i Do . Any Suggetions
 Post subject: Re: Seagte Hdd Eeprom Chip Failed
PostPosted: November 9th, 2016, 1:10
PLZ GIVE FULL MODEL HARD DISK AND TAKE PIC BOTH SIDE FRONT AND BACK
REGARDS :- https://www.facebook.com/Galaxy-Compute ... 230196828/
PostPosted: November 10th, 2016, 16:46
What is the part number of the drive?
I can recover some of them without original rom.
PostPosted: November 10th, 2016, 16:57
As Galaxy said, you need to provide at least a model so we halfway understand the situation. If it's an older U5 Seagate you can probably just get a same FW PCB to replace it, but if it's a newer F3 you're probably up a creek with no paddle.
PostPosted: November 10th, 2016, 17:17
Can you read ROM chip in reader?
PostPosted: November 18th, 2016, 15:20
you must check chip's leg or fallen component via magnify..
if you power the board without TVS diode, eeprom chip probably die.
Users browsing this forum: Google [Bot], sixsweets and 44 guests
