 Post subject: Need ROM: WD10TPVT
PostPosted: August 2nd, 2012, 14:23
Hi all,
I have 2 of these WD10TPVT drives. They spin up to about half speed, slow down for a split second, try spin up again to full speed, then spin down before reaching full speed. Heads stay parked.
The following has been ruled out: PCB, heads, motor/spindle. Drive spins up to full speed and clicks with another PCB without native ROM, as expected.
All that is left is a ROM issue. This error appears in kernel mode:
Techno mode key
Techno mode key......................... : Ok
Debug Stop Code......................... : DEBUGSTOP CRT RAISE
I'm in need of the following ROMs please:
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 08.0CB
ROM generation.......................... : 08.0CB
Link table version...................... : 02.0B.
Consolidated ROM version................ : 0008000C
and the other drive is:
ROM:
ROM version............................. : 08.06B
ROM generation.......................... : 08.06B
Link table version...................... : 02.07.
Consolidated ROM version................ : 00080006
Many thanks,
Nick
Data Recovery Cape Town
 Post subject: Re: Need ROM: WD10TPVT
PostPosted: August 2nd, 2012, 19:24
Is it the one you need?
http://forum.hddguru.com/scorpio-blue-not-recognised-t22865.html
I still have copy on my hard drive. I didn't receive help on the subject, but if my ROM will help you, I don't mind. Let me know.
PostPosted: August 3rd, 2012, 1:55
I somehow forgot to mention these drives are WD10TPVT-00U4RT1
SAjunky, I don't think your drive has the same issue as these 2, you said yours was attempting to initialise 5 times then stops. These don't even spin up to full speed before spinning down with original ROM.
Need ROM for these 2.
PostPosted: August 3rd, 2012, 3:10
This should really be in the PC-3000 section of the forum.
I have put a thread there instead: rom-needed-wd10tpvt-00u4rt1-t23635.html
Mod can remove this one.
Apologies and thanks.
PostPosted: March 23rd, 2017, 13:06
Did ROM fix this for you? Have the same drive, same symptoms, same error.
PostPosted: March 23rd, 2017, 13:12
This was 5 years ago, I can't remember :)
PostPosted: March 24th, 2017, 8:43
TRY http://firmware.hddsurgery.com/
Users browsing this forum: Google [Bot] and 197 guests
