 Post subject: clearing dos config table
PostPosted: August 22nd, 2017, 1:56
first connecting terminal to the hdd I got F3>T but started dos table read fail.then went to 7th level waited for long time & got error again restarted terminal & went to 7th level & issued m100 & same error continued, below is the attached error file for reference No data required .
hdd model st500dm002 date code is 12286 fw jc4b.
Rst 0x10M.docx [10.01 KiB]
Downloaded 583 times
 Post subject: Re: clearing dos config table
PostPosted: August 22nd, 2017, 23:23
You must have PCB from another drive (or another FW version). The log you posted does not look like JCxx firmware.
PostPosted: August 23rd, 2017, 1:08
friend this hdd has latest firmware u need to short the pcb after second spinup msg appear in cmd after complete calibration of hdd then after ready status or any error or getting t mode u need to follow 0 capacity method
m0,2,2,,,,,22
/1
N1
then power reset
then use these three commands
F3T> F00A2,00,22
then F01E4,00,22
then F057C,043C,22
then /1
then N1
then power reset
this is correct method
if hdd is giving access to sector already and showing capacity then use only congen commands to stop relocations of bad sectors.
F00A2,00,22
F01E4,00,22
F057C,043C,22
regards Galaxy
https://www.facebook.com/Galaxy-Data-Re ... 230196828/
PostPosted: August 23rd, 2017, 2:24
Do you understand at least 1% of your advice?
PostPosted: August 23rd, 2017, 5:32
Well,
Welcome To HDDguru Robin :D
PostPosted: August 23rd, 2017, 6:52
Your mistake. Im not Robin
PostPosted: August 23rd, 2017, 8:08
Well,
In That Case May I Know Who You Are
PostPosted: August 23rd, 2017, 19:20
Rst 0x10M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
ASCII Diag mode
F3 T>
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
Input_Command_Error
F3 T>/
No HOST FIS-ReadyStatusFlags 2002A1857
F3 7>X
Failed to load overlay 00000004
LED:000000CC FAddr:00287865
F3 T>
ASCII Diag mode
F3 T>/7
ASCII Diag mode
F3 T>
F3 T>/7
F3 7>m100
PostPosted: August 23rd, 2017, 23:20
http://globaldra.org/ I'm from Russia
PostPosted: August 24th, 2017, 11:21
This is the o/p file of that board.
New Skews Pharaoh 0J with VTPI.docx [10.36 KiB]
Downloaded 487 times
PostPosted: August 24th, 2017, 15:33
New Skews Pharaoh 0J with VTPI,RAP16,Common Code 4,6gig
Product FamilyId: 3F, MemberId: 06
HDA SN: 9VY*****, RPM: 7201, Wedges: 120, Heads: 1, Lbas: 00001D1C5970, PreampType: 73 03
PCBA SN: 00007209RNDJ, Controller: YETIST_3_*/4_0(64A1)(3-12-4-1), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000
Package Version: PH0J2C.CCD4.JM0B9Y., Package P/N: 100668854, Package Builder ID: P9,
Package Build Date: 04/08/2011, Package Build Time: 15:06:35, Package CFW Version: PH0J.CCD4.00343866.P900,
Package SFW1 Version: C289, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 04081506, CustomerRel: JC4B, Changelist: 00343866, ProdType:PH0J.CCD4, Date: 04/08/2011, Time: 150635, UserId: 00410638
Servo FW Rev: C289
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 0A 1B 03
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 enabled
Several examples here:
viewtopic.php?f=1&t=27708
 Post subject: FAIL Servo op100
PostPosted: August 29th, 2017, 13:18
to hdd experts I have five boards giving the same errors as in attachement I want to know the cause of error & why in terminal this error occurs isolating the board from HDA.
Boot 0x10M.docx [10.41 KiB]
Downloaded 477 times
PostPosted: August 29th, 2017, 16:14
Do you know what a servo is?
BTW, why do you insist on encapsulating a few lines of text in an MS doc file?
Boot 0x10M
FAIL  Servo
Resp
=0003
ResponseFrame
0000
0000
0000
0000
0000
0000
0000
0000
0000
0000
repeated 10 more times
Overlay 4 must be loaded from SA to provide support for terminal commands.
PostPosted: August 30th, 2017, 7:58
Well Venkatesh ,
i am not discussing your issue here but what frank is saying i will elaborate .Just 2 to 3 days back i got a seagate drive with overlay error and it spins down ,This clearly says that heads are not ok and it cannot load critical modules from platter sa area .So head change is definately required in my case .In your case too you can try that ,BTW i already have 3 main data recovery guys from bangalore sending me physical cases on routine basis .if you like i can have a peek to your case in my cleanrooms
PostPosted: August 30th, 2017, 10:02
To
fzabkar
please understand with pcb not connected to hda this error appear interminal
Boot 0x10M
Spin Up
FAIL Servo Op=0100 Resp=0003
ResponseFrame FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000F
ResponseFrame 2E9C 0603 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00000
& please how to solve this problem & what is fail servo, as i understand is motor controller chip is failed is it true.
PostPosted: August 31st, 2017, 7:41
pkvenkatesh wrote:
To
fzabkar
Boot 0x10M
Spin Up
Sir ,
Come on What Kind of Question is This ,Call me and i will Explain You
Users browsing this forum: Google [Bot], mima85 and 57 guests
