 Post subject: Model: TOSHIBA MQ01ABD100M ( G-list Error )
PostPosted: September 10th, 2018, 5:59
Toshiba 2.5" 1TB
G-List Error
Smart Cleared
G-List Clear Error
User Sector Error, Any Help or suggestion?
Selected family:MQ01ABD
Model:TOSHIBA MQ01ABD100M
Load Zones : .........................:OK
Cyl Num : ............................:215669
Head Num : ...........................:4
Vendor : .............................:TOSHIBA
Model : ..............................:MQ01ABD100
Microcode : ..........................:AXG01UA9
G-List Reading : .....................:Err
CP list:33,34,44,56,92,95,98,9A,9C,A2,A5,A7,A8,A9,AA,AD,AE,B1,B3,BB,BF,C1,C5,C6,C7,C8,C9,CB,CD,D0,D1,D3,D4,D6,D7,D9,DA,DB,DC,DD,EF,F1,F3,F4,F7,F8,FA,FB,FC,FF
Saving CP module......
Save to folder:C:\UserDataFile\Toshiba\MQ01ABD\20180910-144718\Data\CP\
33 : .................................:Err
34 : .................................:Err
44 : .................................:Err
56 : .................................:Err
92 : .................................:Err
95 : .................................:Err
98 : .................................:OK
9A : .................................:OK
9C : .................................:OK
A2 : .................................:OK
A5 : .................................:OK
A7 : .................................:OK
A8 : .................................:OK
A9 : .................................:OK
AA : .................................:OK
AD : .................................:OK
AE : .................................:OK
B1 : .................................:OK
B3 : .................................:OK
BB : .................................:OK
BF : .................................:Err
C1 : .................................:Err
C5 : .................................:Err
C6 : .................................:Err
C7 : .................................:Err
C8 : .................................:Err
C9 : .................................:Err
CB : .................................:Err
CD : .................................:Err
D0 : .................................:Err
D1 : .................................:Err
D3 : .................................:Err
D4 : .................................:OK
D6 : .................................:OK
D7 : .................................:OK
D9 : .................................:OK
DA : .................................:OK
DB : .................................:OK
DC : .................................:OK
DD : .................................:Err
EF : .................................:Err
F1 : .................................:Err
F3 : .................................:Err
F4 : .................................:Err
F7 : .................................:Err
F8 : .................................:Err
FA : .................................:Err
FB : .................................:Err
FC : .................................:Err
FF : .................................:Err
CP Saving module is ok!
 Post subject: Re: Model: TOSHIBA MQ01ABD100M ( G-list Error )
PostPosted: September 10th, 2018, 16:58
Can you upload the resources, including a ROM and track dump?
I suspect that most of the CP errors are bugs in your tool.
PostPosted: September 10th, 2018, 18:16
I think the problem should be no accessing SA/Data area. Probably bad heads or media damage, since he can only read CP from PCB and nothing from SA...
ACELab partner
PostPosted: September 11th, 2018, 7:43
Track 1 damaged, need to read it first, than write it to repair the logical damage.
PostPosted: September 11th, 2018, 16:30
There are several "Err" CPs which are ROM resident, eg 33, 92, 95. I believe these "errors" are due to a bug in the tool rather than a damaged ROM. A ROM dump would enable us to confirm this. In any case these false errors are obfuscating the real problem.
PostPosted: September 11th, 2018, 18:21
MRT does that even on healthy drives, so I don't care it too much.
ACELab partner
PostPosted: October 23rd, 2018, 10:46
Have you given the case closed or do you want to get the data from that disk?
