Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: SP SSD S55
PostPosted: July 30th, 2019, 15:30
Wow ,
Do Try this Experiement Worth It ,But The SSD Should Not Be In Busy Mode IMHO Otherwise Its Waste ,Might Be It Gets Out Of Busy Mode If We Increase Decrease Voltage To NAND
PostPosted: August 1st, 2019, 15:42
Sorry for the delay. I will get to this soon. Had a few RAID's in all with rebuild issues.
PostPosted: August 1st, 2019, 19:44
Our little experiment didn't work on this occasion. I think the principal was good, but the drive still goes BSY trying to read a sector. The drive stopped responding altogether at 2.7v, which I guess is no surprise.
It is a strange one. The generic utility in PC3000 even reports SMART status....
PostPosted: August 1st, 2019, 20:29
Did you try raising the voltage above 3.3V?
PostPosted: August 1st, 2019, 20:48
Yes I went to 3.6v. The reader goes to 4.0v but did not want to go that high.
PostPosted: August 3rd, 2019, 13:09
Thanks for indulging me. Perhaps the technique may work for other candidates. Better luck next time.
PostPosted: August 3rd, 2019, 14:30
Thanks for the help. Now we know the technique I am sure we will have many more to try.
PostPosted: August 13th, 2024, 3:44
Ok i am digging this up cause i find it fascinating, and having the same exact problem. And might even get lucky with it
So i have a case https://forum.hddguru.com/viewtopic.php?f=10&t=44566
Upon using MPTool to read out Chip IDs i found out Bank 4 of Chip 4 is wrong, Instead of 84 it shows 8C
However, when doing chip-off to id it on PC3000 i get a good ID with 1.8V Vcc 1.8 Vccq
So now im trying to find a way to send out 1.8V Vcc to that chip/
Thanks fzabkar for pointing out the right direction
File comment: Faulty chip and Back
File comment: Front
File comment: Not Faulty in PC3000 Chip off VCC 1.8
File comment: Faulty ID in MPTools
Users browsing this forum: jcan and 24 guests
