 Post subject: Need Rom
PostPosted: August 28th, 2019, 11:12
WD1602ABKS-18N8A0
 Post subject: Re: Need Rom
PostPosted: August 28th, 2019, 11:30
What version are you looking for ?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: August 28th, 2019, 12:11
patient pcb is dead replace donor board can't get fw version .
PostPosted: August 28th, 2019, 12:19
Did you try to read ROM via the serial port?
Why not use any ROM and recreate ROM from SA?
PostPosted: August 28th, 2019, 12:33
PostPosted: August 29th, 2019, 7:08
Select random family. 》go in WD marvel. 》stop action. 》power of on
Pres the button seems bios chip that above test menu》 boot rom mode 》 continue this screen and mostly possible to read rom here
If not work (mostly working) desolder bios and read by external chip reader. Etc etc
But in Picture that you added , look like PCB failure. Look bottom. Drive not ready or busy. Cause
1) PCB or TVS failure or 0 ohm resistor problem.
2) wrong or corrupted ROM
Sexy Womans from your town
Users browsing this forum: Google [Bot] and 132 guests
