 Post subject: Problem with HDD Raw Copy Tool creating corrupted .img file
PostPosted: October 4th, 2020, 11:48
I'm trying to make a backup image of a 500GB drive that was inside a iMac (APFS file system), and now in a USB enclosure connected to a Windows 10 PC.
The HDD Raw Copy Tool successfully create a .img file in about 4 hours, but then when I try to mount this file to view the content, with Windows's integrated image tool, or with WinCDEmu, both saying the .img file is corrupted.
What to do ?
 Post subject: Re: Problem with HDD Raw Copy Tool creating corrupted .img f
PostPosted: October 4th, 2020, 17:22
Can DMDE see the file system when the drive is inside the enclosure? Did you verify that the file system could be mounted by your Mac OS?
I'm wondering whether the enclosure has a 4KB sector size.
PostPosted: October 4th, 2020, 18:57
The drive can be mounted with Paragon APFS for Windows, I have successfully mounted it and copied all files manually to another drive, but some files paths were too long and couldn't be copied so I wanted to make an image of the drive instead, so I found this HDD raw copy tool, but I am wondering if the generated .img is a normal .img or is it specific to HDD raw copy ? Or maybe GB is too big to be mounted as a virtual drive ?
The drive is working when it's inside the iMac
PostPosted: October 5th, 2020, 4:29
As Fzabkar mentioned, you can check the paths/files visibility in DMDE.
You can do the same for image you've created.
data recovery Poland
PostPosted: October 5th, 2020, 18:12
I opened the .img with DMDE successfully, so the .img is probably not corrupted, however it seems that this program cannot find APFS partitions
PostPosted: October 5th, 2020, 18:36
guix,
DMDE 3.7.1.779 Beta (2020-08-15)
N APFS support (without encryption)
PostPosted: October 5th, 2020, 19:31
Yes! With the latest beta, it worked... Thanks all ;)
SOLVED
Users browsing this forum: Google [Bot], MasterT and 112 guests
