Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: ST2000DM001 doesn't spin - Need a lot of advices
PostPosted: November 11th, 2020, 8:30
Just did!
PS: That is the rom I composed with like 20 dumps. Want me to send ALL dumps? :roll:
Thing is when I click on READ, it gives me pieces of the rom... I don-t know how to explain it.
PostPosted: November 11th, 2020, 9:40
ouch...
try soldering wires as i suggested to avoid bad contacts and breaking the pins.
PostPosted: November 11th, 2020, 10:01
edit: thin, insulated wires, like 0.2mm that do not stress the pins.
PostPosted: November 11th, 2020, 14:47
The first half of the ROM looks OK, according to F3RomExplorer. However, the second half is a corrupt copy of the first half. F3RomExplorer refers to this second half as "extra space", so I'm wondering why. Maybe you should patch the ROM so that offsets 0x40000 - 0x7FFFF are identical to 0x00000 - 0x3FFFF?
F3RomExplorer:
http://www.hddoracle.com/viewtopic.php?f=22&t=2534
Don't worry about the bad CRC for the IAP. That's normal.
PostPosted: November 11th, 2020, 14:51
And how do I do that? How does one patch a ROM? And what "patch" does to the ROM?
PostPosted: November 11th, 2020, 15:06
This is how F3RomExplorer parses the second half of the ROM:
I have attached the modified ROM (with identical halves).
Generated_ROM_equal_halves.7z [178.84 KiB]
Downloaded 887 times
PostPosted: November 11th, 2020, 15:24
Thanks so much!!!!!!!! Looks like there's still a chance!
With my (Generated) ROM, HDD didn't spin.
However, with your ROM, it spins but it isn't detected by Windows.
Damn... so close and so far at the same time. Because now that it spins (No bad noises tho), it may still be corrupted or damaged mechanically?
PostPosted: November 11th, 2020, 15:33
You should obtain a terminal log. For that you need a USB-TTL adaptor (~US$5). The error message will then tell us something about the drive's internal problems.
PostPosted: November 11th, 2020, 15:36
There are a lot of them on the internet to buy... From china it costs like 1 euro (but takes like 1 month), from Amazon it takes like 1 day for 5 euro.
Which one would you recommend me to buy?
PostPosted: November 11th, 2020, 15:39
Measure the voltages at the jumper pins. That will tell you which adaptors will be suitable for your drive.
You didn't bother measuring the preamp, did you? So careless.... :) It would be important to follow our recommendations.
Anyway, it's good no bad noises came out of it.
Now it would be nice to see the terminal output, search for seagate terminal or something similar for how to attach to the drive's diag port, you will need an 1.8V serial to usb adapter and some terminal program like hyperterm, teraterm, etc.
edit: Lol, the same happened as with Dmitris in the other thread, he posted the same thing while i was answering... :)
PostPosted: November 11th, 2020, 15:41
I think the OP needs you to identify the J4 pads.
PostPosted: November 11th, 2020, 15:42
How do I measure the preamp? Preamp is something located inside the HDD, right?
Do I have to open the HDD? I hope I don't because I'm not opening it for any reason. That would be totally a mess.
Edit: I just noticed I missed one of your posts pepe...
Will try to measure the preamps right now... Thank you and sorry for being so careless, I didn't done it on purpose!
PostPosted: November 11th, 2020, 15:43
i told you in pm a couple of hours ago, at least i remember so
PostPosted: November 11th, 2020, 15:46
Ya, you told me in a older post I missed because of the Page swap :(
no, it was here:
https://forum.hddguru.com/viewtopic.php ... 03#p285503
Edit: i mean yes :) again
PostPosted: November 11th, 2020, 15:54
Here is my guess as to the preamp supply test points:
PostPosted: November 11th, 2020, 16:03
Do I have to test it with the pcb off the drive? With no supply?
Anyway the PCB is a good one, and I tested it on another hdd and it works fine.
PostPosted: November 11th, 2020, 16:08
You need to identify the corresponding pins on the HDA (head/disc assembly). Then measure the resistance between ground and each of the +5V and -5V pins. No need to power anything up.
https://hddscan.com/doc/images/hdd_main_parts/HDA1.jpg (heads contacts)
The preamp is inside the drive, not on the PCB.
https://hddscan.com/doc/images/hdd_main_parts/preamp.jpg
https://hddscan.com/doc/HDD_from_inside.html
PostPosted: November 11th, 2020, 16:33
Ah, so it has nothing to do with the PCB, omg.
So I remove the PCB and check just 3 pins?
According to your picture.
PS. Sorry if I'm asking a lot of stuff, sometimes the language makes it difficult plus this is all a new world to me. I'm really trying my best.
PS2: I just realized how much I hate Seagate hdds, not going to buy one anymore in my life. What would be a good one? (If I can get this info recovered, I'll prob pay a cloud service for the most important info and pictures/photos on another hdd and backup that data every few weeks)
Users browsing this forum: No registered users and 61 guests
