 Post subject: HN-M101XBB
PostPosted: November 22nd, 2020, 11:30
Hello
Drive in topic came with clicking ( not the regular noise of failed heads )
Terminal output :
ActiveFW : 00FWVer : 0001SATA PLL cal doneDDR size detected = 8MB DDR size detected = 8MB*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI Found*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI FoundU
S_0SHK NF Cal:18
SO_1
SPU@27'C,4845mV
IS=5
CLA ..36/86
HO..OK
HO RPM=693 OK
AC 1748
ST..OK
mS1 00000003
GT:409
SC(L):4112/42
BE.N:16
LD..OK
UF 3 1stGrayErr Hd:0
UD..OK : 42
PK_3 C: 12 H:0
GT:410
SC(L):4112/32
BE.N:16
LDST..OK
UF 3 1stGrayErr Hd:1
UD..OK : 32
PK_3 C: 32858 H:1
GT:411
SC(L):4110/10
BE.N:17
LD..OK
UF 3 1stGrayErr Hd:2
UD..OK : 10
PK_3 C: 24965 H:2
GT:411
SC(L):4096/28
BE.N:16
LD..OK
UF 3 1stGrayErr Hd:3
UD..OK : 28
PK_3 C: 2540 H:3
GT:412
SC(L):4099/6
BE.N:17
LD..OK
UD..OK : 6
PK_3 C: 22 H:0
GT:412
SC(L):4111/29
BE.N:18
LD..OK
UD..OK : 29
PK_3 C: 65334 H:1
GT:412
SC(L):4113/42
BE.N:16
LD..OK
UF6 GE
UF6 GE
AP:2 C: 0->103987 H:0->0 AP Cnt: 0
UD..OK : 42
PK_3 C: 12 H:0
GT:413
SC(L):4101/11
BE.N:17
LDST..OK
UD..OK : 11
PK_3 C: 35355 H:1
GT:413
SC(L):4098/16
BE.N:17
LD..OK
UD..OK : 16
PK_3 C: 22670 H:2
GT:413
SC(L):4101/34
BE.N:16
LD..OK
UD..OK : 34
PK_3 C: 2573 H:3
GT:414
SC(L):4100/5
BE.N:16
LD..OK
UD..OK : 5
PK_3 C: 117 H:0
GT:414
SC(L):4098/18
BE.N:14
LD..OK
UD..OK : 18
PK_3 C: 33159 H:1
GT:414
SC(L):4096/28
BE.N:15
LD..OK
UD..OK : 28
PK_3 C: 17025 H:2
GT:414
SC(L):4100/43
BE.N:18
LD..OK
UD..OK : 43
PK_3 C: 2467 H:3
Unlatch Fail
UDed
PK_4 C: 2467 H:0
UDed
PK_4 C: 2467 H:0
LED 1102
LED 1102
LED 1102
LED 1102
LED 1102
As I know that LED 1102 is related to damaged heads
So I replaced the heads from identical donor, but it gives the same error.
Any suggestions would be appreciated.
Thanks in advance
 Post subject: Re: HN-M101XBB
PostPosted: November 22nd, 2020, 11:45
Attached FIPS :
FIPS_.rar [523 Bytes]
Downloaded 460 times
PostPosted: November 22nd, 2020, 11:57
Still looks like heads. Do you have another donor handy.
PostPosted: November 22nd, 2020, 12:06
Or maybe media damage..
ACELab partner
PostPosted: November 22nd, 2020, 13:24
PCB maybe?
PostPosted: November 22nd, 2020, 14:03
Tried 3 donors with same message.
That's what I suspected the most.
colanco wrote:
PCB maybe?
This drive is USB 2.0, so I converted it to SATA with good known PCB.
PostPosted: November 22nd, 2020, 14:40
+1 i have worked on simular case like this with same log results always end with LED 1102 and the hard disk still spinning and from the hard disk noise i believe that this noise isn't head issue so i examin the 2 platters and found small scratches on platter 0 and platters 1&2&3 clean with some luck i found 1 matched donor in my inventory after that i make hot sawp and save all critical module from heads 1&2&3 For example slist&tlist&slist
And 1 full module dir from head 1
After that i copy module to donor and make de task and make head map and ignored head 0
And after that i back to utlitily and make smart swap and the hard disk become ready and i think you are know whole the rest of process.
hope this help you
PostPosted: November 22nd, 2020, 20:30
I sent you a pm
PostPosted: November 23rd, 2020, 6:39
Thanks all for your inputs.
Will give it another try, but the problem that I have several opened cases now and time is not on my side.
Will post results asap.
Thank you
Users browsing this forum: Google [Bot] and 307 guests
