 Post subject: ST3000DM001 LED:000000BD FAddr:00006220
PostPosted: January 25th, 2022, 7:33
Hello everyone, I have problem after m0,D,3,,,,,22 failed
This is what I am getting now:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Spin Up
RECOV Servo Op=0900 Resp=0005
(P) SATA Reset
(P) SATA Reset
SIM Error 3005 LBA 0000000000097E40 FD FC373093
RW Error 00000080
MCMainPOR: Start:
User Data Base 00440EB0
Check MCMT Version: Current
MC051: MainPOR: EXCEPTION: Corrupt PRI copy of MCMT
MC063: MainPOR: MCMT SEC copy valid
MC026: Reconstruction: MCMT Reconstruction Start
[RSRS] 0001
MC022: Reconstruction: HeadPtr was unwritten
MC024: Reconstruction: Completed:
[MCMTWS] Tail/Head 0001 0001
MCMainPOR: MCTStateFlags 0000002A MCStateFlags 00400041 Tms 000000FD
SP200: MSPMainPOR Start
MSP MainPOR: 00003000 Tms 000000FD 000000A2 000001B6
MSP MainPOR: Complete
No HOST FIS-ReadyStatusFlags 0002A1A1
Boot 0x40M
Spin Up
Trans.
Spin Up
(P) SATA Reset
(P) SATA Reset
RW Error 00000080
MCMainPOR: Start:
[RSRS] 7D5A
Rst 0x40M
LED keeps comming up and don't let me to send any commands, any ideas?
File comment: This log of m0,D,3,,,,,22
New Text Document.txt [134.3 KiB]
Downloaded 485 times
 Post subject: Re: ST3000DM001 LED:000000BD FAddr:00006220
PostPosted: January 25th, 2022, 11:10
What tools do you have available to you?
PostPosted: January 26th, 2022, 4:09
hello,
I only have TTL adapter with level shifter. I was able to get in before, but now even if I get F3> it doesn't accept any commands
PostPosted: January 26th, 2022, 10:24
Hello, thank you for reply, I only have USB to TTL adapter and 1.8V level shifter. Using realterm to connect
PostPosted: January 31st, 2022, 9:02
So,
I did:
C>U2 (regenerate MCMT and MC)
m0,6,2,,,,,22 (most commonly used to regenerate translator)
Now it seems to be about alright:
ø
Boot 0x40M
Spin Up
Trans.
Spin Up
(P) SATA Reset
Problem is that slip list and P list are extremely long. I am tempted to do following:
T>i4,1,22 (clears G-List)
1>G6A (clear P-List - Not Recommended!)
m0,2,1,,,,,22 ( To rebuilt slip list, V1 )
m0,D,3,,,,,22 ( Format user area partition with repairing of bad sector, auto add bad sector into G list and in the last it will be shifted to P list )
Will this work? There are none data anymore as m0,D,3,,,,,22 failed previously (I think so G list got overfilled)
Any Ideas welcome
PostPosted: January 31st, 2022, 19:06
what is your purpose? recover data or use the drive?
PostPosted: January 31st, 2022, 20:45
Hello, thank you for reply.
At the beginning I was trying to save data, most of it I did save, now I am trying to bring drive back to life
PostPosted: February 1st, 2022, 10:36
:D HDD fixed, all sectors green :D
I did:
T>i4,1,22
T>m0,6,2,,,,,22
T>m0,2,3,,,,,22
1>N1
C>U2
T>m0,3D,,,,,,22
Commands was executed in order them are listed. !!!!All data will be destroyed!!!!
It do Spin up without errors, SMART shows 100% health, I will upload write/read test results when HDD Sentinel finnish testing.
PostPosted: February 1st, 2022, 12:06
Thats good. It looks like a factory pre-conditioning commands they run when they build the drives... The thing is to make sure there is no bad heads or the drive does not develop bad sectors while being used. That being said, I did do something like this before with a 2tb drive before because a bad sector developed in a very important part of the drive and rendered it unusable, but doing some of the above commands got it working without any problems. Although all the data was wiped. I did have backup.
Good job
Just a warning that the commends used will wipe all data, so better not use them if trying to recover data.
PostPosted: February 1st, 2022, 12:59
I could be doing the OP a disservice, but I expect the drive is already listed on Ebay.
PostPosted: February 2nd, 2022, 6:25
:lol: No, its not on Ebay :lol: I will only sell board of it once I finnish with it, it is educational project :wink:
PostPosted: February 2nd, 2022, 6:28
Problem now is that it didn't bypass all bad sectors, anybody knows how to do that manually?
20220202-094719_WR_ST3000DM001-1CH166_S1F0QFQX_CC43-perf.jpg [ 131.89 KiB | Viewed 13067 times ]
20220202-094711_WR_ST3000DM001-1CH166_S1F0QFQX_CC43-temp.jpg [ 139.7 KiB | Viewed 13067 times ]
20220202-094642_WR_ST3000DM001-1CH166_S1F0QFQX_CC43-surface-full.jpg [ 996.24 KiB | Viewed 13067 times ]
PostPosted: February 2nd, 2022, 6:59
I forgot to mention, there was problem with level shifter, I was using simple one that I found on this forum (diodes and resistors)
It only worked time to time. I've got transistor based ready-made voltage translator, that one works 100%, just 1,8V supply need big capacitor (I've used 1000uF/6.3V)
And I am using CH341a programmer, with 1.8V adapter and NeoProgrammer it can read and write bios chip (I did test that, so no more soldering), in serial mode it needs that voltage translator.
Just in case you need pinout, it's here
TTL Adaptor to a Seagate drive _.PDF [218.34 KiB]
Downloaded 490 times
PostPosted: February 7th, 2022, 7:25
As there seems to be serious physical damage, I was tempted to replace platers, but, there is system area on them....
Will PCB bios create it automatically when regenerating tables {C>U2 (regenerate MCMT and MC)} and translator {m0,6,2,,,,,22 (most commonly used to regenerate translator)}?
Or is there any other way?
If I get support I'll try it, as only one plater is damaged, so I can get another broken drive...
PostPosted: February 7th, 2022, 11:38
From all sources that I found, I assembled this command m0,41,3,7,7,,,22
It should use both G and P list and skip physically bad sectors, fingers crossed
Comments welcome
Users browsing this forum: Majestic-12 [Bot], MindMergepk and 59 guests
