 Post subject: MQ01UBD100 Data Recovery
PostPosted: December 23rd, 2022, 9:39
I've got a Toshiba HDD Model: MQ01UBD100 that recently stopped working. Here's the breakdown:
LEDs don't light up on drive
PC does not recognize drive in any fashion
Hard drive spins. No clicking or other concerning sounds.
Here are the PCB images:
https://imgur.com/NYrOEe1
https://imgur.com/RV6a6AU
I looked through other forums and found broken, disjointed answers that didn't confirm what worked and what didn't.
If y'all could help me find the quickest way (that doesn't involve a DR Specialist) to recover the data on this drive, I would greatly appreciate it.
If it matters, I have no issues with moving/replacing chips or using solder.
Thanks,
JP
 Post subject: Re: MQ01UBD100 Data Recovery
PostPosted: December 23rd, 2022, 19:51
Obtain G003235B or G003235C SATA PCB and move the IC602 (WinBond) chip.
PostPosted: December 23rd, 2022, 20:30
Is that a burn spot on the VLI bridge IC?
Was there any soldering activity near the USB connector???
PostPosted: December 23rd, 2022, 21:08
Totally agree - signs of flux around USB header too. Best just order a board.
PostPosted: December 24th, 2022, 0:11
Any difference between the two that matters or is it more that there's more than one compatible PCB?
PostPosted: December 24th, 2022, 1:06
IC602 or IC606?
PostPosted: December 24th, 2022, 2:06
IC602 is the one you need to move or copy. Be very careful -- if you damage this IC, nobody will be able to recover it for you.
Users browsing this forum: No registered users and 78 guests
