 Post subject: ST4000DM005 - any other compatible models for head swap?
PostPosted: December 14th, 2018, 16:59
Hello, did anyone find a compatible heads for ST4000DM005 in any other model? I had only one donor. Used it already and all the DM005 i find seem to be to far with DOM or SN to give them a try. As they are new, there is no other way other than to purchase and check. But maybe someone used other heads?
odzyskiwanie danych
 Post subject: Re: ST4000DM005 - any other compatible models for head swap?
PostPosted: January 30th, 2023, 6:39
hello could you find alternative donor for this model? im having problem to find a DONOR for the st4000dm005. i found a donor very closer but the serial is too different
PostPosted: January 30th, 2023, 8:41
No, i used ST4000DM005 as far as i remember.
odzyskiwanie danych
PostPosted: January 30th, 2023, 22:25
he melvin thank you for your kind answer Sir :)
few of this st4000dm005 around :cry:
. im damn confused..... may i ask Sir? how did you managed to find the right DONOR? should i match all the pn serial date and site ???
PostPosted: January 31st, 2023, 2:01
The only thing that matters is preamp and i think they all have the same. But check.
odzyskiwanie danych
PostPosted: January 31st, 2023, 9:27
you mean even different date and site and serial if the preamp is the same ,heads may works without problem?
PostPosted: January 31st, 2023, 17:15
Yes. The only reason why people check PN,SN,date,code is to get the same preamp. At least that's my opinion.
odzyskiwanie danych
PostPosted: January 31st, 2023, 18:45
Preamp and headmap are the only things that need to match.
PostPosted: February 1st, 2023, 4:16
thank you lcoughey Sir. means even different model for example st4000dm004 with my patient ST4000dm005 can be used if the preamp and headmap is the same?
PostPosted: February 1st, 2023, 4:17
im learning more by you guys than so called professional stores around my area. thank you Sir.
PostPosted: March 2nd, 2023, 3:13
guys i still dont know how to find the preamp with pc-3000................. CTRL+L doesnt work.
PostPosted: March 2nd, 2023, 3:21
here is the info of the rom with pc-3000
where is the preamp of seagate v9.txt [3.13 KiB]
Downloaded 405 times
PostPosted: March 16th, 2023, 21:40
hello guys is there a way to find out the preamp from the ROM file when the head died??
i cant find this feature with the latest pc-3000 update .......
PostPosted: March 17th, 2023, 10:07
https://blog.acelab.eu.com/pc-3000-for- ... rsion.html
You can do it from ROM dump and using Hex Editor. Works for all F3 drives except Rosewood.
PostPosted: March 27th, 2023, 8:28
Sir is the V9 a rosewood? my utility seems different from the one on the link you sent me. i dont have PS Physical Heads map button
Users browsing this forum: No registered users and 47 guests
