 Post subject: Dolphin adaptor for Apple A1708 SSD
PostPosted: March 31st, 2023, 14:20
Does anyone have this adaptor? If so, would they be willing to try a simple, safe, no-cost modification to allow it to support those SSDs with the "big inductor at the top left"?
https://www.dolphindatalab.com/product/macbook-pro-a1708-pcie-ssd-recovery-adapter-smart/
If anyone has the other SSD (small inductors), would they be willing to post photos of the innards?
 Post subject: Re: Dolphin adaptor for Apple A1708 SSD
PostPosted: April 1st, 2023, 17:42
I have collated some information on this SSD and the various adaptors:
https://www.hddoracle.com/viewtopic.php?f=106&t=3252
PostPosted: April 4th, 2023, 16:41
I have it. Let me know how i can help you.
PostPosted: April 4th, 2023, 16:52
I contacted Dolphin and asked them if connecting an external 12V supply to pins 1, 2 and 3 of the adaptor would enable it to work with the "big inductor" SSD. They said it wouldn't work. :-(
Ace's adaptor is very clever. It uses pins 1 and 2 of the SATA power connector (these pins are "reserved" or unused) to control the SSD via I2C. When the SSD becomes unresponsive, Ace's Portable can toggle the SSD's hardware reset pin(s). I doubt that Dolphin's adaptor is able to do this, but a look inside the metal can would be very useful. Also, a photo of both sides of the m.2 adaptor would provide a lot of clues, too.
I think Ace's Portable might be able to control other devices via pins 1 and 2. I expect that the unit either has a dedicated I2C host controller, or perhaps Ace bitbangs a couple of GPIO pins to simulate an I2C port.
PostPosted: April 6th, 2023, 11:26
U1 is the 53rd and 55th pins that NB3N3002DTG connects to the M.2 interface, used as an external clock generator for PCIE host. U2 is TCA9534PWR, an 8-bit expansion chip from Texas Instruments that expands to 16 bits of I/O, used to distinguish whether the hard drive inserted into the interface is using SATA or NVME protocol. Power on/off control is handled by the P3 Portable host. As for determining whether SSDs are frozen, I think it should not be a hardware issue with the converter but rather a status register in either NVME or SATA protocol.
http://flash-matrix.com/
PostPosted: April 6th, 2023, 12:39
Thanks, but that's a different adaptor.
PostPosted: April 8th, 2023, 17:29
Can you show us photos of the m.2 adaptor and a photo of the inside of the metal can?
PostPosted: April 10th, 2023, 1:24
make your own adapter :D
A1780.rar [5.84 MiB]
Downloaded 339 times
PostPosted: April 10th, 2023, 13:01
Thanks. I have already collated the same information at my HDD Oracle thread.
Users browsing this forum: jimmydata and 17 guests
