 Post subject: Seagate - ST500DM009-2F110A FW CC34 Fixing And Prob MRT Bug
PostPosted: July 29th, 2023, 4:55
Hi ,
The Disk in Question is Seagate ST500DM009 , With PCB Number 100774000 Rev D . Hard drive was water logged ,so PCB likely could be a issue ,Specially that thermister error in terminal "But i am not sure " , The EPROM No was " 25Q00811 " Looks like micron to me .I did take a backup of the content in My EPROM programmer , Plugging it To PC3K i get the following terminal .Thermistor error might not be a error i do not have donors for this drive "But arranging " .
Boot 0x20M
SpinUp
Trans
Rst 0x20M Thermistor Temp 0018
Retry delay
Retry delay
DOS:0 Scan Unit
LD:
PP:
LED:0x000000EE FAddr:0x003211FC
Cannot access terminal as only for a very brief period it responds to CTRL+Z and then the LED:0x000000EE FAddr:0x003211FC Error pops up . Does anyone have idea which are the short points for read channel ,i have identified 3 locations on board but i am not sure . I was thinking i will try virtual boot of MRT ,The problem is that MRT takes a default of 512KB ROM size which is wrong ,But you can force it to read 1024KB ,But the problem is in the virtual load Menu it does not let you select a rom size for programming . I am attaching original ROM in this post .Kindly rename ROM to .bin extension after you download it to your PC
ROM-05290.zip [1 MiB]
Downloaded 234 times
 Post subject: Re: Seagate - ST500DM009-2F110A FW CC34 Fixing And Prob MRT
PostPosted: July 29th, 2023, 5:15
Well,
just a update i got hold of a HDD with similiar PCB and this is the terminal
Boot 0x40M
SpinUp
Trans
Tech Unlock Handshake: 0xF677BB85
Reply:
Rst 0x40M Thermisor Temp 0019
2Sync:01 0E
2Sync:01 0E
2Sync:01 0E
(P) SATA Reset
LD: Size:00000028 HBlocks:0000 Size:002BFDDF HBlocks:0032 Size:00283137 HBlocks:0032 FlashRestore 00000000 00000028 E2C3
PP: Size:0000B400 HBlocks:0000 FlashRestore
PVTSize: 00013D7C CompSize: 0000028A DeCompSize: 00013D7C 00000000 0000028A A942
2Sync:00 04
DSP06AD
PS : This is ST1000DM010 Though PCB is Same ,The the thermister error seems to be ruled out
PostPosted: July 29th, 2023, 19:40
I think "Thermistor Temp 0018" is just reporting the temperature inside the HDA, namely 24C (= 0x18).
PostPosted: July 29th, 2023, 21:12
The actual content of your ROM ends at 0x7F210. The second half of the ROM ("extra space") appears to contain "noise". This "noise" includes a full backup of the RAP and a partial backup of the SAP.
BTW, why can't you just ZIP your file? :-?
PostPosted: July 30th, 2023, 1:15
I will keep your suggestion in mind next time ,What do you think about this case ,Parsing Sys file 93 shows that this drive does not have media cache ,I used PC3K Ver 7.0 . I was able to get Terminal Access using MRT Virtual Boot/Start ,But No Sector Access , Although Drive is 1 Platter + 2 Heads i think only 1 head is used .
PostPosted: July 30th, 2023, 16:06
F3RomExplorer reports that the drive has 1 head.
PostPosted: July 31st, 2023, 14:53
There should have been from platter.
But it did not read. And there is garbage in RAM.
PostPosted: August 1st, 2023, 1:31
There is no any garbage in RAM. Just 40 (3_1d2) is unreadable and that's it.
PostPosted: August 1st, 2023, 16:19
i was thinking the same but could not find the same fw version a few days ago, now i found it and proved.
PostPosted: August 2nd, 2023, 5:10
Hi ,
Everyone ,Thanks for the inputs ,I had never seen this and hence did not know ,The party has taken it back ,i will try and ask him to send me the hdd back ,Cheers ,3_1d2 is replaceable from identical fw or not .
Users browsing this forum: Google [Bot], Rendersmith and 50 guests
