Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
 Post subject: ST1000LM024 is spinning but not reading nor detecting!
PostPosted: June 16th, 2024, 11:46
Hello everyone! Can you guys guess what's going on with this drive! Cause it's very important to me! It's spinning but it's not detecting on windows nor it doesn't made any detection noise just spins that's all! Any help would be highly appreciated Image
 Post subject: Re: ST1000LM024 is spinning but not reading nor detecting!
PostPosted: June 16th, 2024, 12:42
That's a Samsung model. Show us the terminal log.
PostPosted: June 16th, 2024, 16:49
BTW what's a terminal log??
PostPosted: June 16th, 2024, 16:50
How do I open a terminal log!
PostPosted: June 16th, 2024, 16:54
How to connect a terminal adaptor on a Samsung drive ?
https://www.hddoracle.com/viewtopic.php?f=116&t=189
PostPosted: June 17th, 2024, 2:44
Connected! And now what to do??
PostPosted: June 17th, 2024, 2:52
Power it up and record the terminal log.
PostPosted: June 17th, 2024, 4:22
How?? Do I do that??
PostPosted: June 17th, 2024, 9:11
The PuTTY terminal is blank. If I type something it's garbage no text only ascii's any help
PostPosted: June 18th, 2024, 12:18
Could anybody help me on this please!
PostPosted: June 18th, 2024, 14:32
For testing purposes, connect Tx to Rx on your adaptor and then type something. You should see a local echo.
Measure the voltages at the HDD's Tx and Rx pins. Set the I/O voltage of your adaptor to the same I/O voltage as the HDD. (eg 1.8V to 1.8V, 2.5V to 2.5V)
Then connect Rx to Tx, and Tx to Rx, between your adaptor and HDD. Select the appropriate baud rate, parity, start/stop bits, data bits in PuTTY.
PostPosted: June 19th, 2024, 2:24
Can't this be a step by step procedure sir??
PostPosted: June 19th, 2024, 2:33
Step #1: For testing purposes, connect Tx to Rx on your adaptor and then type something. You should see a local echo. This is called a loopback test.
Step #2: Measure the voltages at the HDD's Tx and Rx pins. Set the I/O voltage of your adaptor to the same I/O voltage as the HDD. (eg 1.8V to 1.8V, 2.5V to 2.5V)
Step #3: Then connect Rx to Tx, and Tx to Rx, between your adaptor and HDD. Select the appropriate baud rate, parity, start/stop bits, data bits in PuTTY.
Step #4: Power on the drive and show us the terminal output.
PostPosted: June 19th, 2024, 3:05
numbers remove duplicates
It's the same thing
PostPosted: June 19th, 2024, 4:24
3,5 inch Samsung SATA hdd:
[''''''''PWR'''''''''] ['''SATA'''] [ : : : | ] RX / TX
2,5 inch Samsung SATA hdd:
[''''''''PWR'''''''''] ['''SATA'''] [ TX RX X X ]
HDD Samsung Marvell chip:
Bits per second - 57600
Data bits - 8
Parity - None
Stop Bits - 1
Flow Control - None/Hardware
HDD Samsung Samsung chip:
Bits per second - 38400
Data bits - 8
Parity - None
Stop Bits - 1
If the HDD on a separate power supply is connect HDD GND to the adapter GND.
PostPosted: June 22nd, 2024, 13:12
..OK
..OK
eng>01
    E:0001
E:0001
eng>eng>
        E:0001
E:0001
eng>
    E:0001
E:0001
eng>
    e'▒▒▒j
          E:0001
eng>
    eng>
        E:0001
E:0001
eng>
    E:0001
E:0001
eng>E:0001
eng>'&LLLCQ
▒▒01
E:0001
eng>
    eng>
        eng>
E:0001      E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
eng>E:0001
e▒>E:0▒>E0001
eng>E:0001
eng>E:0001
eng>E?▒▒▒j
          eng*:0001▒&▒▒j
en
This is what i'm getting
PostPosted: June 22nd, 2024, 13:48
After power-on, you should see something like this:
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 8MB
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI Found
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI FoundU
PostPosted: June 23rd, 2024, 0:29
But that's what I'm getting and when I try it again it doesn't show anything just a green cursor on PuTTY and nothing. What might be the issue??
PostPosted: June 23rd, 2024, 0:42
ActiveFW : 00
             FWVer : 0001
                         SATA PLL cal done
                                          DDR size detected = 16MB
           *PAUNI_L2958*PA VID=0011 PN=000D Rev=0000- PA_LSI2958 Found
        *PAUNI_L2958*PA VID=0011 PN=000D Rev=0000- PA_LSI2958 FoundU
S_0SO_1
SPU@32'C,5138mV
IS=2
CLA ..36/87
HO..OK
HO RPM=628 OK
AC 1690
ST..OK
mS1 00000003
GT:434
SC(L):4145/76
BE.N:35
LD..OK
SK C:  3162 H:0
[DF_TMOUT0:0000:0000]
SR:0
SR:0
AP:2 C:  7285->  7285 H:0->0 AP Cnt: 0
SK C: 53534 H:0
SR:1
AP:2 C: 53534->  7285 H:0->0 AP Cnt: 0
SK C: 62710 H:0
S_0SR:0
SK C: 59157 H:0
SR:1
AP:2 C: 59157->  7285 H:0->0 AP Cnt: 0
SK C: 64858 H:0
now i'm getting this!
What shoud i've to do now!
i cannot type on that page!
PostPosted: June 23rd, 2024, 1:49
May i ask what hardware or software you are using to read the values?
Munnar Anneh must be very angry.
Users browsing this forum: No registered users and 104 guests
