 Post subject: WD101EFAX HSA replacement,
PostPosted: June 17th, 2024, 18:17
Hi All,
I was hoping someone can offer some ideas to help me come to a resolution.
I have 2 WD101EFAX drive, and the read / write heads have gotten damage.
Does anyone know if I can find the Head Stack Assembly by it self, or where can I find a Donor Drive for a resonable price.
Lastly, where could i find the schematics for this same drive?
The PCB number is 004-0B43167 and the dirve is a WD101EFAX WD RED 10TB PLUS, any info is greatly appreciated, thank you in advanced JR.
 Post subject: Re: WD101EFAX HSA replacement,
PostPosted: June 17th, 2024, 18:36
I can help you repair the PCB if you upload detailed photos. This PCB has two stages of protection -- smt fuse, TVS diode and e-fuse. There is one set for the 5V rail and a second set for the 12V rail.
https://ae01.alicdn.com/kf/H79771994e51c4c379ed54dff2d6b2e69Q/0B43167-Hitachi-IBM-Western-Digital-Enterprise-Hard-Disk-Circuit-Board-004-0B43167-001-0B43167-0B43166.jpg
PostPosted: June 17th, 2024, 19:45
Hi Fzabkar,
Thank you for the information, My main concern with the PCB is that I swapped the board on my unit with a donor I purchased on ebay.
I want to be sure I swapped the bios / memory chip correctly.
This board seems to have two chips, from the littleb bit of infomation I found online, it recommended to swap both chips. After swapping the PCB, I am now getting the machine to recognize the drive, however when i try to initiate the drive I get an error:
" The request could not be performed because of an I/O device error."
I reached out to WD support and their best guest is that the heads are not working properly, since the drive does not have any warranty left I decided to try and repair it my
self. And this is how I ened up on this site.
PostPosted: June 18th, 2024, 11:48
How did you damage the drives?
BTW, I've seen many DR pros try to swap heads on these models without success. I suspect that the "adaptives" need to be transplanted.
PostPosted: June 18th, 2024, 22:40
Thanks fzabkar :D
Is there anyway I can communicate with you out of forum ( on email or other means )
PostPosted: June 19th, 2024, 12:36
I would prefer that problem solving questions remain in the public domain. I don't know who you are or where you are. In any case, I'm not a DR pro, just an interested observer.
PostPosted: June 19th, 2024, 20:19
Understood .Thank you
Users browsing this forum: No registered users and 58 guests
