 Post subject: st500um001 not spining
PostPosted: November 11th, 2024, 6:28
Hello .
I have a seagate st500um001 hdd thas not spinning .
I suspect the rom as f3explorer says there is a bad IAP .I dont know how to repair this rom.
Please help.
 Post subject: Re: st500um001 not spining
PostPosted: November 11th, 2024, 6:38
IAP doesn't have a checksum, AFAIK.
What do you see in terminal?
PostPosted: November 11th, 2024, 7:03
I dont have terminal now. But can you examine my rom if you can identify any errors.
PostPosted: November 11th, 2024, 12:31
Yes, upload the ROM. Sometimes PUIS (Power Up In Standby) is enabled. The PUIS flag is stored in the IAP segment.
PostPosted: November 11th, 2024, 23:37
st500um001 W25Q80BW@SOIC8-150_20241109_124158.rar [619.99 KiB]
Downloaded 141 times
Thats my rom file attached . Please analyse if you can help
PostPosted: November 12th, 2024, 0:16
I can't see anything wrong.
Edit:
I now see that this is an SSHD, in which case I suspect that there may be a problem with the NAND flash.
https://www.seagate.com/content/dam/seagate/migrated-assets/www-content/product-content/seagate-laptop-fam/laptop-thin-sshd/en-us/docs/100725146e.pdf
PostPosted: November 12th, 2024, 5:29
Edit:
Can I use a donor pcb from a similar sshd and move the rom chip to the donor and expect better results.. Does the nand chip have any drive specific code in it?
PostPosted: November 12th, 2024, 5:33
A ROM transfer doesn't work on other Seagate SSHDs, so I doubt it will work in your case.
Users browsing this forum: No registered users and 249 guests
