Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST3500312CS PROCESS DEFECT LIST ERROR
PostPosted: May 21st, 2025, 13:56
SWM wrote:
Dear kagzizaid80 sir,
These commands only do harm. Especially to data recovery.
As well as recalculating the translator without a backup of system files.
And it is impossible to restore erased P-list records. They are unique for each disk.
For your level of knowledge - listen to the pepe:
"without knowhow you better outsource it..."
Ok. Thanks SWM Sir. I will return back this hdd to customer.
Case close.
PostPosted: May 22nd, 2025, 1:54
try one thing:
write this into beginning of 1B:
Offset      0  1  2  3  4  5  6  7   8  9  A  B  C  D  E  F
00000000   00 00 00 00 00 00 9D 8F  00 00 00 00 00 00 00 00
00000010   00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
don't regen translator, just try lba access after power cycle.
PostPosted: May 22nd, 2025, 8:56
pepe wrote:
try one thing:
Thank You Pepe Sir,
I will do and update you sir.
PostPosted: May 22nd, 2025, 9:39
kagzizaid80 wrote:
pepe wrote:
try one thing:
Thank You Pepe Sir,
same problem pepe sir. partial access.
PostPosted: May 22nd, 2025, 9:48
first you wrote you can't access sector, to me this means no LBA access. You didn't write wether capacity is OK. Now you write partial access, it is confusing.
If you have partial access, what's the last lba you can read?
PostPosted: May 22nd, 2025, 10:04
Dear Pepe Sir,
Please see attach pic, When i got hdd it has partial access problem. All sector bad reported by R-Studio. When i apply translator regeneraton command i got Process defect list error. when googling i found that sys file 1B has problem accroding to various forum.
PostPosted: May 23rd, 2025, 7:42
Dear Pepe Sir,
Please Update PEPE Sir.
PostPosted: May 23rd, 2025, 8:23
Partial access means drive is able to read user area up to a specific LBA. You say all sectors are inaccessible, ie this is not a partial access problem. Without tools you will likely cause more harm than good, plugging defective disks under windows is a very bad idea anyway.
PostPosted: May 23rd, 2025, 8:33
ok sir
thnx
Users browsing this forum: No registered users and 637 guests
