Post new topic Reply to topic  [ 427 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22  Next
 Post subject: Re: New version of R-Studio
PostPosted: October 12th, 2023, 14:09
A new build of R-Studio for Windows (9.3.191248). Several important improvements and bugfixes.
R-Studio Data Recovery Software
PostPosted: October 21st, 2023, 10:26
I have experienced some issues with new version (windows) It is giving error -failed to open. There is no scan progress bar which stucks up at 0%.
There is no current lba sector no displayed as well.
can you pls. fix these in new build.
PostPosted: October 24th, 2023, 8:10
Please contact our techsupport on our site. They'll help you to solve this problem.
PostPosted: October 26th, 2023, 15:38
A new version of R-Studio (9.3.191251). Several important bugfixes.
PostPosted: October 30th, 2023, 12:51
Hello
Did you find the problem ?
I tried the demo version R-Studio 9.3.191251, it's the same problem.
PostPosted: October 30th, 2023, 13:00
The problem is occurring in the “cracked” version
PostPosted: November 23rd, 2023, 16:28
New build of R-Studio. Some means to decrypt deleted volumes (mainly APFS). Plus bugfixes. https://forum.r-tt.com/viewtopic.php?f=13&t=12007
PostPosted: December 29th, 2023, 13:35
A new version of R-Studio for Linux (5.3.191267). Keeping it up with its Windows counterpart.
PostPosted: April 15th, 2024, 15:43
A new version of R-Studio (9.4)
New features
Technician/T80+
+ Multitasking. Several different tasks can be performed simultaneously. For example, you can create a multi-pass image using a third-party hardware, scan a disk image, and recover files from another image, all at the same time. The number of concurrently performed tasks depends only on the computer efficiency (CPU, RAM, HDD/SSD, etc). Each task runs in its own tab and can be controlled individually. Computer shutdown takes place when all tasks are completed. The list of running tasks is displayed on the Main panel in the lower left corner.
+ Hidden devices. Devices that are not subject to scanning for data recovery can be hidden from the Main panel (System disks, devices for storing recovered data, etc). Such hidden devices are still accessible for storing recovered files, logs, scan info, etc.
Plus changes, improvements, and bugfixes.
PostPosted: June 18th, 2024, 16:43
A new version of R-Studio for Linux.
Keeping up with R-Studio for Windows
PostPosted: June 18th, 2024, 22:37
Thanks for update ,
Is linux version also can be self booted from a USB pen drive ? Can it write recovered data on NTFS partition ?
I have not tried Linux version so far .
PostPosted: June 19th, 2024, 11:44
R-Studio Emergency (a startup version of R-Studio) is a separate product bundled with R-Studio for Win/Linux. There are two versions of this program, based on Linux or WinPE. You may find more on this page: Download R-Studio for Linux.
Yes.
PostPosted: June 25th, 2024, 10:15
A new build of R-Studio (9.4.191329). Several improvements and bugfixes.
PostPosted: August 30th, 2024, 15:47
A new build of R-Studio (9.4.191349). Improvements and bugfixes.
PostPosted: November 11th, 2024, 12:17
Hi
Im the only one that could not stop scanning once I start? the only way to stop from task manager.
PostPosted: November 11th, 2024, 17:35
siamak5561 wrote:
Hi
you and everyone that use cracked version.
PostPosted: June 3rd, 2025, 15:53
A new version of R-Studio (9.5) is available for download.
New features
+ Support for Windows Storage Spaces up to Windows 11 24H2.
Technician/T80+:
+ USB activation. A dedicated USB activation stick can be created to eliminate the need to activate a copy of R-Studio Technician over the internet when using this stick. Additionally, startup/bootable and/or portable versions can be installed on this stick making it a complete solution for data recovery.
+ Support for DeepSpar USB Stabilizer 10GB™.
+ Support for editable advanced multi-pass imaging settings.
+ Support for consecutive imaging as FS bitmap + Unused clusters and Unused clusters + FS bitmap.
+ Added some advanced options for a conventional file enumeration and a new mode Show Files (Advanced). This new mode performs file enumeration only in the selected folders. Very useful for slow and damaged disks.
The build-in File Viewer
+ Added support for many RAW photo image file types.
Plus improvements and bugfixes.
PostPosted: June 12th, 2025, 3:32
Alt(R-TT) wrote:
Does it support also Guardonix?
My firmware database:
PostPosted: June 23rd, 2025, 12:34
R-Studio for Linux 5.5.191537. Keeping up with its Windows counterpart.
PostPosted: June 23rd, 2025, 12:54
Its a shame the Technicians license has almost become unusable.
Users browsing this forum: Google [Bot] and 45 guests
