Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: How to fix the SSD of the body of this thread using RAID
PostPosted: August 13th, 2026, 12:10
Yes, they are.
PostPosted: August 13th, 2026, 12:13
Yes, they are, but only on the SSD, not on the RAID drive.
Last edited by gamingnogaming on August 13th, 2026, 12:15, edited 1 time in total.
I didn't realize that it showed that the messages had been edited when I edited my posts on this forum, and since I needed you to read edited messages, I had to mention that they had been edited. But now that I know the forum indicates when a message has been edited, I don't need to do that anymore.
PostPosted: August 13th, 2026, 12:18
And I won't do it.
PostPosted: August 13th, 2026, 12:30
You have two drives in your computer, an SSD and an HDD.
gamingnogaming wrote:
Seagate ST1000DM003-1SB102 1,000.2 GB SATA III 6 Gb/s internal HDD, and a KingSpec P3-256 256.0 GB SATA III 6 Gb/s internal SSD
What RAID drive are you talking about?
So you can see your files on the SSD.
This means no array is configured.
Show the partitioning of the second disk in DMDE.
There is a damaged partition on the SSD (B red mark - volume boot sector), you need to repair it (which is risky without making a disk copy), or recover the data immediately (for example via DMDE), which is also risky without a disk copy.
Or maybe I don't understand something...
PostPosted: August 13th, 2026, 13:29
This is the Seagate ST1000DM003-1SB102 1,000.2 GB SATA III 6 Gb/s internal HDD. As I have already mentioned, this is not the HDD I used to create the RAID. I will show its partitioning in DMDE in the attached images, in chronological order from bottom to top.
PostPosted: August 13th, 2026, 13:34
I don't understand... Why are you showing devices that aren't affected by the problem?
You were supposed to post a screenshot of the main partition window, not everything you deem appropriate - these screenshots are useless...
I'm afraid I can't help you remotely, your descriptions are too chaotic.
PostPosted: August 13th, 2026, 13:48
The SSD shown was affected by the problem. I showed that HDD because I believed you wanted me to do that, and I will also show the affected HDD. How can I identify the affected HDD if I don't remember which one it was?.
PostPosted: August 13th, 2026, 14:01
How can I display the main partition window in DMDE? Please explain it in a way that someone with no computer knowledge can understand. Please forgive me for copying what I copied; I believed I was helping. From now on, I will ask what you want me to show before showing it, so I don't show unnecessary information.
PostPosted: August 13th, 2026, 14:35
Now I don't understand at all.
You wrote that your drives are in a RAID 0 array: SSD+HDD:
KingSpec P3-256 256.0 GB SATA III 6 Gb/s internal SSD( this is the drive is need to fix)
configured with the SATA Port set to Super Speed and the Storage Configuration set to RAID 0?
Which turned out to be false, at least based on all the information you provided.
Now you write that:
We're supposed to know which of your devices is failing, what you did during/after the failure, and finally, you write that the problem is with the HDD.
What is the main problem or which device is affected by the problem?
This is the main partition window in DMDE:
PostPosted: September 25th, 2026, 18:58
Can you explain what technological method I should use for each drive to determine when it was last used, especially if I don’t know when I last used it or if the drive is damaged? By “my last damaged drive,” I mean the HDD that I used in the RAID setup, and by “the last drive I used,” I’m referring to that same HDD from the RAID setup.
PostPosted: September 25th, 2026, 19:09
Does this forum help with repairing damaged SSDs, or does it only help with recovering data from them?
PostPosted: September 25th, 2026, 19:43
When I said in my second-to-last reply, not including this one, that I wanted someone specific to help me, I actually meant anyone.
PostPosted: September 25th, 2026, 21:28
When I asked if this forum repairs damaged drives, I meant whether they can fix them to make them functional again, not whether they help with data recovery.
PostPosted: September 26th, 2026, 5:29
I'm getting psychotic by just reading this thread.
PostPosted: September 26th, 2026, 19:49
How can I sort files by the date they were last modified, with the most recently modified files appearing first? Please explain it in a way that someone with no computer knowledge can understand.
PostPosted: September 26th, 2026, 22:40
The reason I asked the previous question is because I need to know when the damaged HDD I used last was last accessed, since that’s the drive I used to set up RAID Mode. With the method explained in the answer to my question, it’s possible to determine when a damaged HDD was last used.
PostPosted: September 27th, 2026, 5:04
shouldn't someone with no computer knowledge leave data recovery operations to experts? (without reading through all this thread which i did not have the patience for :s )
PostPosted: September 27th, 2026, 10:03
All file system created at same date, 2026-08-12.
PostPosted: October 23rd, 2026, 15:21
Here’s an image of the HDD I used alongside the previously mentioned SSD in the previously mentioned RAID configuration.
Users browsing this forum: No registered users and 108 guests
