Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: I have a problem with my generic Phison USB.
PostPosted: February 1st, 2026, 20:58
NelsonRomero wrote:
SWM wrote:
Unable to find complete information on the memory chip... Last option...
When I run the process with this version of the program, I get this errors and the Windows warning that appears when the device is not detected, and I notice that the USB automatically disconnects every time I try to flash. I'm already giving up on this USB... :cry: :weep:
UPDATE: After watching tutorials and reading guides translated from Russian, I understand that “test mode” can be activated by pricking certain parts of the USB memory chip with a sharp object (not the PHISON chip, The metal resistors of the Memory Chip). Using this technique, You have to plugged your USB, and at the same time poke it with the pointed object. With that, the USB is connected to the PC and enters “test mode.” In theory, when I restore the USB with the latest program you sent me, it, as far as i know, this happens because of the write protection, which is not removed when the USB was disconnected when i was Restoring it or a USB protection that is removed on test mode. If I find out anything new, I will let you know. If not, then I will hammer the USB. Cheers!. :wink:
PostPosted: August 13th, 2026, 20:16
Any update i have same pendrive and same issues tried short but dont know its working or not. using MPtool on start it goes isp burner then auto stop ? Help me to fix it
