Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: pin for safe mode
PostPosted: September 18th, 2026, 12:49
Hi everyone, this NVE is compatible with the PC3K, but I need to know which pins to use to put the drive into safe mode; has anyone worked on this before?
CT500P3SSD8E
Italia Assistance Data Recovery
Italian data recovery lab – HDD, SSD, NAS, RAID
Professional data recovery lab
 Post subject: Re: pin for safe mode
PostPosted: September 19th, 2026, 18:14
How about those two BIG holes at the end of PCB?
odzyskiwanie danych
PostPosted: September 20th, 2026, 9:15
i try it but not fuction
PostPosted: September 20th, 2026, 11:18
have u checked the supplies n efuse?
PostPosted: September 20th, 2026, 11:54
I haven't run any tests yet; I was hoping to find someone who had already worked on it to tell me the key points directly :D
PostPosted: September 20th, 2026, 11:55
measure the voltages at the inductors those are the key points
PostPosted: September 21st, 2026, 0:20
by 'Key points' I think they mean the points for shorting for test mode, not key as in relevant
PostPosted: September 21st, 2026, 1:02
What is the point of futzing about with safe mode if the basic tests of hardware functionality haven't been carried out? There are four stepdown converters and one e-fuse. It would take less than 5 minutes to locate the power supply test points and verify them.
PostPosted: September 21st, 2026, 1:23
Similar SSD ...
https://youtu.be/iEeRmszJzt8?t=298
PostPosted: September 27th, 2026, 9:22
i need enter safe mode for upload pc3000 portable loader
PostPosted: September 27th, 2026, 9:28
I gave you your answer ... twice. If you can't enter safe mode, it's because the hardware is broken. You can't fix broken hardware from behind a keyboard. You need to do some real troubleshooting. A competent technician needs only a few minutes to verify the power supplies. Watch the video and learn something.
PostPosted: September 27th, 2026, 9:46
All the capacitors and currents show no signs of imbalance, so—oh genius—if the electronics are fine and I can't get into safe mode via the pinouts, what do *you* think the problem is, in your infinite wisdom?
PostPosted: September 27th, 2026, 10:10
*tension intensifies*
PostPosted: September 27th, 2026, 10:27
All the capacitors and currents show no signs of imbalance ...
My advice is to outsource the job to someone who understands the technology. I confess I have yet to see a "balanced" capacitor. Personally, I would test for "imbalance" at the inductors, but what do I know.
PostPosted: September 27th, 2026, 10:55
My question was: Has anyone worked on this specific SSD and can confirm the safe mode points for me—if they differ from the norm—to save on research time (since nobody pays €7,000 for a data recovery job)? I’m an industry expert and know exactly what I’m doing, but if I can cut down on the legwork, that’s a plus. There’s no need to be condescending; if that’s how you treat clients, I don’t think you’re much of a guru.
PostPosted: September 27th, 2026, 11:19
I provided a video where an experienced technician is working on exactly the same SSD, and I saved you the trouble of watching the entire video by linking to the exact moment where the technician is shorting the safe/ROM mode test points. Why are you still asking the same question? What is your problem, expert?
PostPosted: September 27th, 2026, 11:42
I hadn't seen the video; the fact remains that you're responding as if you're on your period.
PostPosted: September 27th, 2026, 12:02
Then show me some respect and watch the video.
PostPosted: September 27th, 2026, 12:20
if u want to respect, give me your respect, if u are in red period it is not my fault, adios.
PostPosted: September 27th, 2026, 18:34
fzabkar is all over the internet with their research and work. Who are you? lol
