 Post subject: ST12000NM001G
PostPosted: October 28th, 2026, 9:23
Hello
Drive in topic (Evans-EXOS) came with 11x12 TB similar drives in QNAP (Raid 5)
All sectors shows ABRT.
NVC Format Corrupt.
Any suggestions?
 Post subject: Re: ST12000NM001G
PostPosted: October 28th, 2026, 10:03
Can you upload the ROM dump(s)?
PostPosted: October 28th, 2026, 10:16
Sure, thanks in advance
Uploaded patient and one of the working drives (Raid members)
Patient.rar [238.68 KiB]
Downloaded 26 times
Working Raid member.rar [258.32 KiB]
Downloaded 25 times
PostPosted: October 28th, 2026, 10:26
I think those PCBs have two ROMs in a RAID configuration. Your patient dump has no NvC component.
Also, your dumps seem to be twice as large as they need to be. The second half of each dump is empty.
PostPosted: October 28th, 2026, 10:33
That's true.
Must use advanced method to unlock.
PostPosted: October 28th, 2026, 10:37
I comapred two ROMs from two working drives and they seems fine. And I noticed a lot of differences in different places when compared to the patient ROM
PostPosted: October 28th, 2026, 10:39
Here's another dump from another working drive
Another working member.rar [259.62 KiB]
Downloaded 27 times
PostPosted: October 28th, 2026, 11:48
The NvCache area is located at 0xA0000 in your working dumps. Your patient dump is empty. How can the NvC be corrupt if it hasn't yet been created??
PostPosted: October 28th, 2026, 13:05
If you need a PCB, avoid this seller:
https://www.harddrivesdirect.com/products_image_large7.php?products_id=731675_ST12000NM001G
https://www.serverpartsdirect.com/images_large/sea_SATA_3_bottom.jpg (AI generated PCB, very very weird)
https://www.serverpartsdirect.com/images_large/ST4000NM0034_4.jpg (AI generated label, wrong model number in file name)
PostPosted: October 28th, 2026, 21:42
no no... they can now print the PCB's in 8K... The chip names look like Russian Klingon ;-)
"BART NUMBER" SERIAL NUMEER"
just think that in a few years, AI will be choosing our medication and administering it with no human contact...
PostPosted: October 29th, 2026, 10:49
PostPosted: October 29th, 2026, 10:50
Or maybe worse.
PostPosted: October 29th, 2026, 10:51
Problem temporarily solved and I could clone the drive.
PostPosted: November 1st, 2026, 2:42
oh
https://www.cnet.com/tech/services-and-software/woman-died-after-chatgpt-advised-her-to-stop-taking-medication-lawsuit-alleges/
Users browsing this forum: Google [Bot] and 93 guests
