 Post subject: Intenso 256GB - dead
PostPosted: Yesterday, 11:11
Hello forum,
let me introduce myself briefly, i am an electronic engineer from Germany and htis is my first encounter with SSD failures.
So i dont know about PC3000 or SMI MP-Tool .
I had this Intenso 256gig SSD drive plugged into USB via USB-Adapter and last action was to erase a bigger file.
I then just pulled it out of the USB port of the Windows PC.
Later re-inserting it - and - nothing. No Drive Letter appeared. It was non existend. completely dead.
I had some important files on it.
Ok, i searched the forums, reading about ROM mode, flash chip identification, PC3000 rescue software and the SMI tools.
I checked the Voltages, 3.3V, 1.2V and 0.9V, all good.
There are 3 LEDs og which the middle LED was constantly on, indicationg ? Power?
Then there are these jumper connectors, 2 upper, 4 lower.
I guess the top one is for ROM mode, the others are ??? what?
ROM mode is when the sm2259 controller enters a service mode ?
What can you then read out of it ?
ched some light in my empty brain ;)
 Post subject: Re: Intenso 256GB - dead
PostPosted: Yesterday, 12:17
Did the SSD identify itself in ROM mode?
For reference ...
BL8028, Shanghai Belling, Synchronous Buck Converter, 1.5A, 2MHz, 2.6V - 5.5V in, marking GUyw, SOT23-5:
https://www.belling.com.cn/media/file_object/bel_product/BL8028/datasheet/BL8028_V1.13_en.pdf
PostPosted: Today, 8:56
I do not know howto enter ROM-mode.
Do you know which jumpers i have to short to enter it? ( see foto)
What are all the other 4 jumper/connector-holes for?
If in ROM-mode, PC will see what?
PostPosted: Today, 9:23
Sorry, i just tryd it with the upper jumper and it worked.
ROM.png = Devicemanager Ankeje USB3.0 SCSI Disk
diskman.png = Storage management, new Disk_1 , 1GB, not initialized
OK
PostPosted: Today, 9:53
That means that the SM2259XT controller has basic sanity, which in turn suggests that the SSD has a firmware problem, probably due to bad NAND.
