 Post subject: IsSamsung PM991a Embedded SSD recoverable ?
PostPosted: November 25th, 2026, 4:15
I have got samsung nvme SSD model PM991a . It has lost detection & gets heated up after few seconds. Most of the electronics seems to be ok.
Is it possible to recover this embedded model & whether MCU is supported by PC3000 portable ?
Thanks.
 Post subject: Re: IsSamsung PM991a Embedded SSD recoverable ?
PostPosted: November 25th, 2026, 10:26
Most of those have internal shortage of controller and there is no way at the moment to fix it.
793561753_1569486821641555_1542317637636071289_n.jpg [ 102.58 KiB | Viewed 2601 times ]
odzyskiwanie danych
PostPosted: November 25th, 2026, 10:34
What are the supply voltages?
PostPosted: November 26th, 2026, 10:45
Thanks fzabkar
Fortunately customer is electronic expert and he has tested components & corresponding voltages , I will get them from customer & will update.
PostPosted: November 26th, 2026, 10:56
Since you are taking data recovery jobs, you should learn how to do those trivial tests yourself. Or do you reject those jobs that require electronics knowledge?
PostPosted: November 26th, 2026, 11:11
Thanks melvin
only corner of the chip is getting hot , hope chip is not internally shorted. Is there any way to conclude by checking voltages .
PostPosted: November 26th, 2026, 11:19
terminator2 wrote:
Thanks melvin
You check for short circuits by measuring the resistance. You check the voltage to confirm that the overheating problem is/was not the result of an overvoltage from a faulty regulator/converter.
I have a question for you. Would you take your car to a mechanic who knows nothing about engines, but who still expects to fix them from behind a laptop?
PostPosted: November 27th, 2026, 4:30
100 % agreed with you fzabkar ,
Despite having electronics background I have not developed basic skills .
PostPosted: November 27th, 2026, 4:33
terminator2 wrote:
Thanks melvin
Agreed Instead of inhouse testing & other related work (like rom swap etc) I outsource all my work.
I regret I didn't developed skills .
PostPosted: November 27th, 2026, 11:10
Following are voltages
PostPosted: November 27th, 2026, 11:41
Those readings all look reasonable to me. The PMIC appears to be a Silergy part (marking DCDxyz), but I haven't been able to locate a datasheet.
The resistances between each test point and ground will tell you whether there is an obvious short on any of the supplies.
PostPosted: Yesterday, 3:59
Thanks fzabkar
It seems indeed there could be shortage inside monolith itself.
PostPosted: Yesterday, 5:16
You can always move the chip to another PCB or adapter to check. I've had a few of those and all of them were unrecoverable.
odzyskiwanie danych
PostPosted: Yesterday, 22:34
Why Franc? are you thinking of retiring from the Electronics support center for HDDGuru? ;-)
PostPosted: Yesterday, 22:35
LMFTFY
"Let me Fzabkar That For You"
PostPosted: Yesterday, 23:03
During the early years of data recovery, electronic problems were solved by PCB swaps. Then along came "adaptives", and these people then needed to learn how to use a soldering iron to transfer ROMs between PCBs. All was good until SSDs arrived. Then these ROM jockeys and headswap mechanics realised that they hadn't learned anything during all those years. Luckily, NAND is sufficiently unreliable to enable them to make a living fixing translator problems from behind a keyboard. Many still haven't bothered to learn how to use a multimeter and perform the most basic tests.
What other field enables people to advertise a repair service for a product they know nothing about, especially when they don't possess even the most rudimentary skills? There are people whose only troubleshooting tool is an IR camera. That's something a mechanic could do. Clients entrust their precious data to people whom they think are experts in their field. If I were in this business, I would do my utmost to learn the requisite skills. Unfortunately, there is no accreditation body to enforce these requirements.
PostPosted: Today, 18:54
It is similar everywhere. Mechanics rely on OBD tools to tell them what's wrong, washing machine repairers just swap boards (Though some are encased in epoxy, so a little different), 'homemade' Pasties use the same chopped up veggies supplied from a factory as half of their competitors. In my field of tech work, I have had a few younger 'tech's' that if the solution is not on Reddit, or ChatGPT doesn't have an answer, they just re-image or bin the device. No troubleshooting skills, no understanding of what logs files are telling them, no memory of work we did 3 weeks ago, and no real enthusiasm for tracking down issues.
I had a guy here for a year and one story as an example. We were troubleshooting aa SCCM server and he found a post saying look at a certain log. There was no log, so I said I think we just need to turn on Auditing for it to create the log. 15 years in tech supposedly and he had not heard windows logging called Auditing, or even ever turned a log on. 15 f***g years?
PostPosted: Today, 19:50
I recommend this Youtube channel for SSD repairs and troubleshooting:
https://www.youtube.com/@XFJDIY/videos
The guy uses a USB voltage and current monitor to give him a rough idea of the problem. He then measures the voltage test points. He will test the resistances at these same points if there is an overload. He will also confirm it with an IR camera. This all happens within a few minutes.
If he suspects that the controller is dead, he will check whether it IDs in safe/ROM mode. The USB current draw will also tell him whether the controller is running or inactive.
Users browsing this forum: Google [Bot] and 13 guests
