 Post subject: Problem with WDC WD400LB-07DNA2 HDD
PostPosted: September 4th, 2005, 15:28
Hi !
I have problem with WDC WD400LB-07DNA2 HDD...
Drive is detected by BIOS
Configuration sector is readable
DLGDIAG QUICK TEST -> RESULTS - "SMART ERROR"
I think that drive have errors in SA (Firmware errors), but I'm not sure...
50 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 00
[WDC WD400LB-07DNA2    ] [   78,165,360] [      283,560] [  EST:    2:18:02  ]
ţ Smart -> ATT
Getting SMART attributes... OK
            Name                        Val Worst Raw
Att #   1 : Read error rate           : 200    1  0
Att #   3 : Spin up time              :  87   86  2166
Att #   4 : Number of spin-up times   :  96   96  4657
Att #   5 : Reallocated sectors count :   1    1  26906
Att #   7 : Seek error rate           : 200  199  0
Att #   9 : Power-on time             : 100  100  265
Att #  10 : Spin-up retries           :  47   46  12352
Att #  11 : Calibration retries       : 100  100  321
Att #  12 : Start/stop count          : 100  100  46
Att # 194 : HDA Temperature           : 115  253  28
Att # 196 : Reallocate event count    :   1    1  4108
Att # 197 : Current pending sectors   : 254  200  0
Att # 198 : Offline scan UNC sectors  : 199  199  8
Att # 199 : Ultra ATA CRC Error Rate  : 200  253  4192
Att # 200 : Write error rate          : 200   85  8
ţ Log saved to file: LOG\smart.log
| Select a drive : <SHIFT+F3>                                       | 18:51:20
DLGDIAG.LOG
09/04/2005, 20:47:04
SELECTED OPTION - "SMART STATUS"
SELECTED DRIVE -
          Model : WDC WD400LB-07DNA2
            S/N : WD-WMADY12*****
       Firmware : 79.07B79
          C H S : 77545 16 63
       Capacity : 40.0G
          Drive : 0  Port: 0x170
ERROR/STATUS CODE = 0159
59 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 10
[WDC WD400LB-07DNA2    ] [   78,165,360] [             ] [                   ]
Supports: LBA48 HPA AAM DLMC LBA MS16 DMA (UDMA5,MWDMA2)
SMART: Enabled SelfTest: Supported ErrorLog: Supported
Security: high, OFF. Size = 38166MB
MHDD>.wd
MHDD ATA/SCSI TERMINAL v2.1
Script: WD
ţ Reset...
ţ Reading Configuration Sector
ű Configuration Sector (wd.bin) has been written
MHDD>.test
Script: TEST
ţ Simple test script
ţ Reset...
ţ Getting identify information
ű identify.bin has been written
ţ Reading 100 sectors starting from LBA 0
ERROR: Look at the registers
| Take a screenshot : <F10>                                         | 19:03:12
 Post subject:
PostPosted: September 5th, 2005, 0:42
Rewraite 44 and 25 modules from other HDD and afterwards clean Glist
Afterwards - format its...
If in 25 modules were not brought tracks from SA, that you carrying
 Post subject:
PostPosted: January 10th, 2006, 17:01
it's problem in translator. use pc-3000 and regenerate translator. empty g-list, don't write module.
http://www.yudiharddisk.com
 Post subject:
PostPosted: January 20th, 2006, 10:49
No, it's not a translator problem. Some of the SMART modules are damaged. Find and fix them.
 Post subject:
PostPosted: January 25th, 2006, 17:37
No, it's not a translator problem. Some of the SMART modules are damaged. Find and fix them.[/quote]
ok, sory i am wrong.
 Post subject:
PostPosted: January 26th, 2006, 2:41
from the smart attributes log it is obvious that Glist is full.
I would empty Glist and zero fill the drive and see if it still contain bads.
regards,
 Post subject:
PostPosted: January 26th, 2006, 5:21
regards,
Even if you empty the G-list Smart will report bad. That is why you have to rewrite Smart table with a good one!
 Post subject:
PostPosted: April 21st, 2006, 7:45
Can anybody send me modules 25 and 44 for this HDD (WD400LB-07DNA2)
PZU: 79.06.
SA FW: 79.06B.
TS: 07.4D.
Mikippp
Users browsing this forum: Google [Bot] and 248 guests
