 Post subject: Vendor for Maxtor 250gb logic board?
PostPosted: March 7th, 2006, 15:09
Need a replacement logic board for a Maxtor MaxLine Plus II 250gb ATA/IDE HDD. Logic board indicates as follows:
301862101 Calypso/Koi P/Therm M8FYB
Any suggestions? thx!
 Post subject:
PostPosted: March 10th, 2006, 12:47
search on google. found one site long time ago http://www.ultratec.co.uk
they have lots of PCB's and HDD
In the UK but shipping to USA was about $40
:O)
A man is as old as he feels, and a woman as old as she looks
 Post subject: Found a vendor
PostPosted: March 20th, 2006, 11:32
http://www.softcom.com.my/
Just ordered the appropriate logic board from the above vendor. He sells it for $15 plus about $40 shipping from Malaysia. I will report results.
I have also read a string somewhere about difficulties in getting replacement logic boards to work since the bad block map or whatever it's called is not the same as the original. There were a variety of difficulties in doing this relatively simple operation which I will provide here if I can locate the link on my other computer.
Steve
 Post subject:
PostPosted: March 20th, 2006, 18:13
hi, the "bad block map" isnt on the pcb. u have to pick up the proper pcb or if you have the tools, you can fix it
regards
 Post subject: Received PCB
PostPosted: March 31st, 2006, 11:13
Received the goods as promised, and he sent me two for the price of one! Maybe there are two versions of the board and felt I should have both [??] One component that says "1R5" is different on each board. Don't know if that means anything. Will update if I can resurrect the drive.
steve
 Post subject:
PostPosted: April 3rd, 2006, 0:44
The component with the '1R5' marking is the inductor for -5V power supply, it has nothing to do with FW version.
Users browsing this forum: Majestic-12 [Bot] and 111 guests
