 Post subject: 4D clicking
PostPosted: April 10th, 2007, 15:58
I have a problem with a PCB of 4d040h2 when i plug that pcb to any drive it starts clicking and after i remove that pcb and plug a completly functional one
it start working fine . I want to know what could be the problem with the PCB .
Below i am attaching a picture of a 4d040h2 pcb please tell me which componenet could cause such a problem . So i can replace it .
Thanks in advance .
 Post subject:
PostPosted: April 10th, 2007, 23:21
Did you try to replace of IC SH6770C, that is the power cotrol?
 Post subject:
PostPosted: April 11th, 2007, 16:18
i will try it thanks . Could there be problem in the Agere m5453 thats the spindle controller chip ?
correct me if i am wrong.
thanks
 Post subject:
PostPosted: April 12th, 2007, 11:41
U are wrong :)
the agere IC is the reading/writing channel.
U should check the -5V power line if the drive is clicking with only this PCB.
I think somebody in DR businnes should have at least basic electronic education to recognize the parts, engineer level is recommended...
regards,
 Post subject:
PostPosted: April 12th, 2007, 14:05
thanku for ur reply if there is problem with the 5V power line then i should chek the DC-DC convertor .
 Post subject:
PostPosted: April 12th, 2007, 14:52
:idea:
 Post subject:
PostPosted: April 12th, 2007, 15:53
What?
 Post subject:
PostPosted: April 13th, 2007, 15:09
I mean yes, check the converter wether it produces a stable -5V for the preamp!
regards,
 Post subject:
PostPosted: May 6th, 2007, 15:03
normally from this IC SH6770C hdd click specially 4d0 .
PLS check from other pcb number B9FDA or B9FDB
firmware cod : DAHO17K0
Users browsing this forum: Google [Bot], Jonny_Quick and 294 guests
